Author Topic: 1966 SJ Mustang C code. Red primer found under original paint ??  (Read 921 times)
Offline Norcal87
« on: November 11, 2019, 09:59:00 PM »
1966 mustang While cleaning my car I notice a redish primer under the paint ??
« Last Edit: May 25, 2020, 06:53:02 PM by J_Speegle »
Re: 1966 Mustang C code. Red primer found under original paint ??
« Reply #1 on: November 12, 2019, 05:26:25 PM »
Considering the mounting hardware in the picture appears to be painted that might not be (very likely isn't)  original paint nor primer  ::)
None of those parts were mounted on the car when painted so none of the hardware would be painted either.
Red oxide colored primer was used on the exterior body panels with a light gray filler primer typically before the exterior color was applied though.
Offline Norcal87
« Reply #2 on: November 15, 2019, 11:06:39 PM »
Here’s some new pics I took of the 66 mustang
Offline rrenz
« Reply #3 on: November 16, 2019, 09:37:10 AM »
Typical for the underside to have red oxide visible as thats all it was typically sprayed with. I was able to clean the underside of my 66 up and looks brand new.  But as Jeff said your headlight bucket hardware is painted so its obviously had some work done in that area
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Offline Norcal87
« Reply #4 on: November 16, 2019, 05:42:31 PM »
Another picture.
« Reply #5 on: November 16, 2019, 05:55:33 PM »
The last picture, the shot behind the grill, is most likely not factory. Those pieces were painted off the car in another area.
How about listing the plant and scheduled build date.
A couple of shots of my (sold down under) 66 GT Fastback, San Jose, 28 March scheduled.
