Author Topic: speedometer cable routing 70 Dearborn  (Read 3290 times)
Offline bgp429
« on: November 02, 2019, 03:41:57 PM »
Couldn't find a picture of the spedo cable routing. I think this car has been "modified", tried routing the cable with the brackets like they are but burnt it up. First picture is the right side of the floor. The bracket must have a use but what? The second on is the bracket on the left side, think it is indexed incorrectly. Should it have a spedo adapter? Thanks
Car is a late Dearborn 70 Boss 302.
« Last Edit: November 02, 2019, 03:48:44 PM by bgp429 »
Re: speedometer cable routing 70 Dearborn
« Reply #1 on: November 02, 2019, 08:27:21 PM »
Couple of pics from my 69.  Should help out until Jeff comes along ?  Brian
Offline bgp429
« Reply #2 on: November 02, 2019, 10:44:32 PM »
Great, so that bracket is probably right. Just purchased a body assembly manual tonight. Hopefully it will have decent diagrams. Thanks
« Last Edit: November 02, 2019, 10:48:22 PM by bgp429 »
Offline rockhouse66
« Reply #3 on: November 03, 2019, 09:50:49 PM »
I think you will need the Chassis Assembly Manual to help you with the speedo cable.
'66 GT FB
Offline bgp429
« Reply #4 on: November 03, 2019, 10:06:43 PM »
That is what I purchased just used the wrong terminology. Thanks
« Reply #5 on: November 03, 2019, 10:48:29 PM »
There is also a Body assembly manual,electrical, engine etc.
« Reply #6 on: November 07, 2019, 09:52:50 PM »
Sorry this took this long. catching up after another trip
From a 70 Dearborn Boss in the 0F142xxx range
Shows the wrap around version of the retainer was used here
Not easy to get a shot with the engine in place
And another - rattle canned black but there  ::) from the 0F181
Hope these help
Offline bgp429
« Reply #7 on: November 08, 2019, 11:45:44 AM »
Thanks for the help. This is where the cable in melting. I know the insulation is tacky. It is temporary until I figure out what is wrong. The clip on the right side floor doesn't seem to be angled to hold the cable.
« Reply #8 on: November 08, 2019, 01:18:45 PM »
Jeffs photo is what I see on rh side 4 speed Dearborn cars and the other type clip is what I see on automatic LH side rear clip.
Offline rockhouse66
« Reply #9 on: November 09, 2019, 08:34:08 AM »
Is this a 3.91 or 4.30 car?  It looks like it would line up and go through the existing clip if you had the speed reducer on the trans.
Here is the underside routing on a car with the speed reducer FYI.
« Last Edit: November 09, 2019, 09:31:19 AM by rockhouse66 »
'66 GT FB
Offline bgp429
« Reply #10 on: November 09, 2019, 12:38:15 PM »
350 gears from Ford. Thought about a reducer [if I could find one] it would fix the problem. Did Ford put a reducer on any other vehicle? Meaning is there a less expensive alternative. Beautiful car by the way.
« Reply #11 on: November 09, 2019, 03:26:07 PM »
There are alternatives and ones used on other vehicles. Have not priced them recently but they will look different if I recall correctly. Looked for a donor one (had the end cap missing from one I had ) a few years back and didn't find any short cut short of making one that made things easier
Also remember that there are two versions - one for manual and oen for automatic transmissions
Offline bgp429
« Reply #12 on: November 09, 2019, 08:00:40 PM »
