So far here is the short list: If anyone has any experience with any of these springs please feel free to chime in. I do plan to strip them and refinish in bare metal.Scott Drake (Photo 1-4)Virgina Classic Mustangs (5-8)JR Springs (9-12)Eaton (No Photo)
I ordered a set of the springs from VCM and they don't look right at all. Ends are flared from stamping? Pictures are attached for reference. Looking for pictures of the Eaton springs if anyone has any.v/rTony[/img]
I wish I could restore mine. They are currently painted but appear to have heavy pitting under the paint.v/rTony
I ended up buying a set of the Eaton springs and am currently in the process of stripping them. They are much closer to originals than the VCM springs without the excessive flaring on the ends. I'm going to try bluing them to get closer to the darkened finish. Will post pictures if they come out right.v/rTony
After Stripping the first one, I'm wondering if I even need to try and darken them by bluing. I've attached a picture for comment on whether it's close.v/rTony
They look pretty close as is but I would like to see them a little darker by bluing given they don't match the darker bottom plate. A closer between the bottom plate and Eaton leafs would be more ideal IMO.
They look great. You can also use graphite to darken them, but the graphite is a dark grey and not as black as the gun bluing I find. Did the leaves come with the bushings pre installed. Obviously you you swapped out your original bot tom leaf.
