Author Topic: 65 K code sticker location help  (Read 957 times)
Offline rtate
« on: October 04, 2019, 06:43:04 PM »
I have a 65 convertible K code built in Dearborn December 64,
I am restoring the engine bay and would like to know what stickers were used and where they are located.
Also any other identification markings like grease paint etc. would be great !
Not building a 100 point car but trying to be as accurate as possible.
Cheers !!
December 10/64 Dearborn K code, Convertible
Silver Smoke Gray
Re: 65 K code sticker location help
« Reply #1 on: October 04, 2019, 10:47:24 PM »
Off the top of my head - will try and post a collection of supporting pictures
- Service decal - Drivers side shock tower
- Battery inspection sticker filled out correctly - Passenger side front inner fender panel near starter relay
- Engine ID sticker - for a December/November built engine think it was still on water pump neck
- Engine cubic inch decal - - Flat outer ring of air cleaner lid
- AUTOLITE replacement decal - Opposite side of the air cleaner lid
- There would be a heavy red paper tag stapled in two places that attaches over the pig tail wire for the radio resistor at the voltage regulator. Not really a decal but a bonus to the discussion
Similar car, production period and plant - just a month different and different engine
Ignore the notes and pictures that do not relate to your car's details
http://www.concoursmustang.com/forum/index.php?topic=19263.msg121592#msg121592
As mentioned in other threads I don't suggest you buy one of the kits and built individual quality stickers there is often a big difference.
Kits will include stickers for things that were originally ink stamped and are often incorrect for your car. This woul dinclude things like starter, ignition coil and voltage regulator cover.
« Last Edit: October 05, 2019, 12:10:25 AM by J_Speegle »
« Reply #2 on: October 05, 2019, 12:24:47 AM »
From examples built at Dearborn around Dec 64
- Service decal -
And a close up.
- Engine cubic inch decal - This example didn't get either of the AUTOLITE  style decals. Have seen a few examples of this taking place
- Heavy red paper tag at the radio resistor pig tail at the voltage regulator.
Offline rtate
« Reply #3 on: October 05, 2019, 11:16:39 AM »
Thanks Jeff !
Was there a tag on the Positive battery post as well ?
Silver Smoke Gray
« Reply #4 on: October 05, 2019, 11:56:49 AM »
if you are referring to the white/red plastic tag that comes with the repro battery then no it is not correct. in fact it was not even available back then.
« Reply #5 on: October 05, 2019, 03:32:06 PM »
+1
