Author Topic: 67 FE Fuel Pump  (Read 532 times)
Offline orgnl70
67 FE Fuel Pump
« on: September 24, 2019, 07:47:35 PM »
67, 390, FE. GT Heads. What  is the correct fuel pump for this motor. Is it a standard pump or the one with a fuel filter on the bottom of the pump itself.
Any photos would be of great help.
Re: 67 FE Fuel Pump
« Reply #2 on: September 24, 2019, 10:08:44 PM »
The 67 390 Mustang typically would not have the filter made into the pump (filter on bottom). That is because the fuel filter screws into the carb. If it didn't have a filter at the carb then it would use the pump with the filter. 67 GT500 uses the fuel pump with the filter made into the pump because in the case of the GT500 it does not have any filters at the carbs.
Re: 67 FE Fuel Pump
« Reply #3 on: September 24, 2019, 10:49:53 PM »
The 67 390 Mustang typically would not have the filter made into the pump (filter on bottom). ...............
+1
Another thread with a picture of a 67 390 fuel pump posted last year
C6AZ-9350-B - stamped on mounting flange side  - 4194-S. Of course its dated also
Originally cast with CARbureTER on the forward facing face for your application
http://www.concoursmustang.com/forum/index.php?topic=19199.msg121162#msg121162
« Last Edit: September 24, 2019, 10:53:53 PM by J_Speegle »
Offline preaction
Re: 67 FE Fuel Pump
« Reply #4 on: September 25, 2019, 12:16:21 AM »
The 67 pump also uses a 5/16" fuel line.
Offline 1967 GT
Re: 67 FE Fuel Pump
« Reply #5 on: September 25, 2019, 12:19:49 AM »
My apologies. I have a 1967 500. I had forgotten about the filter screwed into the carb inlet. I have no filter on the pump so I am running the FE canister.
