A little more detail if you would - product number, type of container you used, general temperature, any other tips.
Do you think this would work on other powder coated items?
Benco B17 product. Initially tried applying it with a toothbrush, nothing happened, so that's when I filled up a 5 gallon bucket with it and soaked the manifolds. Was surprised that it actually worked. I've used it to strip paint off other parts too, just dip them for about 5-10 mins and the paint falls off. Big time saver for parts that have to be blasted. Had a set of hood hinges with lots of exterior paint over-spray, probably would have taken a couple hours to clean them in the cabinet. Soaked in B17, rinsed/dried and spent 10 mins cleaning in blast cabinet after.
The stuff is a bit pricey, think I paid over $200 for a 5 gallon container.
It's some nasty stuff, need eye/skin protection. I had a small tear in one of my gloves and this stuff got in, had to run to the faucet to rinse off! I only use it outside in the driveway. When I first used it and tried to apply with a tooth brush, it dissolved the tooth brush.
Temp-wise, I don't think it matters, but I'm sure that info is in the tech data.
