Author Topic: 3 Spd trans Identification Question  (Read 1200 times)
Offline Captain Kent
« on: September 16, 2019, 03:37:21 PM »
I think my 3 spd trans (200 6cyl) is from a 69. Can someone verify for me. The data tag on the trans is RAN CA 010040
« Last Edit: September 17, 2019, 04:56:32 PM by J_Speegle »
1967 Lone Star Special. Owned since ‘74
Produced in Dearborn April 7, 67
200 6cyl 3spd
Mustang Monthly; http://www.mustangandfords.com/featured-vehicles/1409-1967-ford-mustang-hardtop-rare-finds/
Re: 3 Spd trans
« Reply #1 on: September 16, 2019, 04:49:29 PM »
First book I pulled out shows it as a 71+72 302 3 speed in a Mustang
With that serial number would guess early 71 production
Will check a couple other sources
69 200 6 cylinder ran a RAN-AM According to Kevin Marti's tag book
Re: 3 Spd trans
« Reply #2 on: September 16, 2019, 05:06:04 PM »
Later MPC lists the -CA as a 71 302 application before 12/1/71
Going to move the thread over to the Drivetrain section of the site for now
Re: 3 Spd trans
« Reply #3 on: September 16, 2019, 05:28:41 PM »
I wonder exactly how the linkage hooks up.
200 6cyl 3spd
Re: 3 Spd trans
« Reply #4 on: September 16, 2019, 06:29:37 PM »
To the steering column or the shifter? With the locking steering column it would have had both
Basically the shifter attachment is pretty standard. Arms connected with nuts. Arms to rods retained with clips. Rods to shifter arms with adjustable pins with clips on one end and securing nuts on the other end of the pins
If I remember correctly there is a hole on one of the transmission selectors that attaches to a rod that goes to an arm at the base of the steering column for the lock out like on an automatic 71-73
Re: 3 Spd trans
« Reply #5 on: September 16, 2019, 06:43:18 PM »
Floor shift. Two places to hook shift linkage, one forward and one rear. My pic below shows how mine looks with 2 places to attach linkage. A normal 3 spd only has one place to hook up. Make sense?
200 6cyl 3spd
Re: 3 Spd trans
« Reply #6 on: September 16, 2019, 07:08:28 PM »
The pic below shows a code
C8AR
7006    C
Mine shows
D2AR
7006    AA
200 6cyl 3spd
Re: 3 Spd trans
« Reply #7 on: September 16, 2019, 07:13:36 PM »
This is how mine looks
200 6cyl 3spd
Re: 3 Spd trans
« Reply #8 on: September 16, 2019, 07:50:51 PM »
Believe the top example shows the two connection spots I mentioned in my response. One for the shifter and one for the lock out steering column used on 71-73s
Codes your showing appear to just be the casting numbers from the main case not the application. The D2 does suggest the later style we're discussing
Here is a 70 4 speed examples - they used the locking steering column arrangement also
The center arm has to connection points one top, one bottom. The three rods (blue arrows) connect to the shifter. Lower one goes to the center arm on the trans \
The one lower connection rod (green arrow) attaches to the steering column lower end so that it can not be moved once the car is locked by removing
the ignition key
« Last Edit: September 16, 2019, 07:58:17 PM by J_Speegle »
Re: 3 Spd trans
« Reply #9 on: September 16, 2019, 11:13:50 PM »
Ok that 3rd hook up if I follow yo7 is probably the key lock. That makes sense now.
200 6cyl 3spd
Re: 3 Spd trans
« Reply #10 on: September 17, 2019, 12:14:42 PM »
There should be a partial VIN stamped on the transmission - see this photo. Generally on the top passenger side but occasionally on the top driver side.
Re: 3 Spd trans
« Reply #11 on: September 17, 2019, 02:58:18 PM »
What is this threaded what looks like a sending unit? It is all the way forward on driver side?
200 6cyl 3spd
Re: 3 Spd trans
« Reply #12 on: September 17, 2019, 04:56:10 PM »
May be a sensor. In 72 they tried some new/different emissions systems. Not really up on 72 6 cylinders but there was a 72 2V V8 application where the automatic transmission was part of the emissions system so guessing this was possibly a similar attempt. Believe the V8 system mentioned above was a one year only thing
