Author Topic: Body code help - 69 63D  (Read 2511 times)
Offline sah62
Re: Body code help - 69 63D
« Reply #15 on: September 12, 2019, 11:43:47 AM »
Deluxe Marti reports include both the body style code and a description of that code as shown in the report attached below. What kind of report do you have? A deluxe or elite report normally includes more than just the code.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline ruger
« Reply #16 on: September 12, 2019, 12:23:40 PM »
Exactly like yours.
Where your door tag body code is 76B mine is 63D.
Gotta be engine related.
1969 Sportsroof Mustang E'
63D
250 six cyl.
C4 trans.
Dearborn build Nov. 1968
« Reply #17 on: September 13, 2019, 10:53:40 AM »
The 250 E engine has a higher compression ratio which is the main difference. How was that achieved? Different pistons? The MPC would say. I do not know why the difference in engine specs would make any difference in the body but there must be something different about the body itself to warrant a different body code.
Exactly like yours.
« Reply #18 on: September 13, 2019, 02:23:13 PM »
......................................I do not know why the difference in engine specs would make any difference in the body but there must be something different about the body itself to warrant a different body code.
Don't think it was a body "need" since the deluxe interior or the bench seat didn't require changes to the body. Its was for some other reason in the company we just haven't found I would think at this point. Any minor need for different holes or a bracket could have just been identified on the buck tag like was done for other models and cars.
Offline ruger
« Reply #19 on: September 13, 2019, 03:51:55 PM »
Here is a picture of the bucktag minus the full vin#    As you can see,  the tag was also primered and painted with silver jade paint as well.
63D
250 six cyl.
C4 trans.
« Reply #20 on: September 13, 2019, 04:26:03 PM »
We've seen the body color going that far forward and some times not at NJ in 69 - Covered over by engine compartment black so it would not show in the final finish
Easy to see from the buck tag not allot of anything extra or different done to the uni-body that was not communicated in the information/coding at the top
Offline ruger
« Reply #21 on: September 13, 2019, 04:30:04 PM »
I am at a loss with the D.   I will eventually uncover something.
63D
250 six cyl.
C4 trans.
« Reply #22 on: September 13, 2019, 10:54:19 PM »
Everyone likes a good mystery.  You mentioned early on that the ' 63D ' is mentioned in conjunction with some engine spec's ?  Would you elaborate as to what those are ?  Brian
« Reply #23 on: September 14, 2019, 12:21:22 AM »
63D I believe is more related to the "package" than just the engine like the 63c was related to an interior, body type and exterior package
Will leave the explaining of the engine to the owner
ruger thanks for reposting the TSB Article- had forgotten I had posted that back when you first joined here
« Last Edit: July 02, 2020, 05:47:26 PM by J_Speegle »
Offline ruger
« Reply #24 on: September 15, 2019, 10:42:54 AM »
Thanks, as far as the engine goes it states a higher compression is used. Also a certain jet in the carb. A 1" larger torque converter also.  I just can't find the exact reason for the D being used.
63D
250 six cyl.
C4 trans.
