Author Topic: dancing amp gauge needle  (Read 2082 times)
Offline CCP
« on: September 09, 2019, 01:53:41 PM »
    The amp gauge on this '66 seems to be fine when I first fire it up, but after only a few seconds begins to fluctuate wildly from side to side, full range of the gauge. The alternator has been rebuilt and the voltage regulator is new. The battery shows 13.1 volts and then jumps up to about 15 with the engine running and a volt meter on the battery terminals.
  Any ideas? Could the gauge be bad?
            Thanks, Pete.
1969 Fairlane Cobra formal roof drag pack
1968 Shelby GT500KR
6F08A-GT,a/c,4-sp.,ps,build date 16A. DSO 24 Jacksonville
Re: dancing amp gauge needle
« Reply #1 on: September 09, 2019, 02:42:00 PM »
Midlife had this same problem, but intermittently, and I was never able to fully rectify the issue.  Now that I know more, I believe there is a problem in connectors or junctions where the ammeter lines are in the engine bay.  If you have a flakey connection inside a molded connector, you'll see rapid changes in resistance and that will be reflected in the ammeter gauge itself, which is designed to accept about 1-2% of the full charging current.
Try tugging on all of the current-charging wires relative to the molded connectors.  Also, crimp ever so slightly the 90* slip-on connectors for the ammeter gauge to ensure they have good connections.
Offline CCP
« Reply #2 on: September 10, 2019, 10:41:25 AM »
  Started by changing the voltage regulator. Put the original one back on and guess what, problem solved. That was something I didn't consider at first since the regulator was a new reproduction right out of the box. Lesson learned, even though something is 'new' doesn't mean it works properly.
  Now,  should I switch to a modern electronic regulator and church it up with the reproduction cover?
                Thanks again midlife.  Pete.
1968 Shelby GT500KR
« Reply #3 on: September 10, 2019, 11:44:13 AM »
Electronic voltage regulators are usually the best choice over the old style breaker-points.
Thought I saw recently that there's a reproduction VR now with the correct base/cover and electronic internals?
Offline CCP
« Reply #4 on: September 10, 2019, 12:26:08 PM »
  That sounds like the hot ticket!   Thanks.
1968 Shelby GT500KR
« Reply #5 on: September 10, 2019, 01:29:08 PM »
Virginia Mustang sells them . I am not sure about NPD.
Offline CCP
« Reply #6 on: September 10, 2019, 01:47:10 PM »
  The new one that was bad came from Larry's. I have a box full of parts like that from them.
1968 Shelby GT500KR
Offline 70cj428
« Reply #7 on: September 20, 2019, 07:13:20 PM »
Quote
Probably not just Larrys, the repro regulator with the conventional (old school points) internals are pieces of crap and I think most of the suppliers sell the same part. Most people buy one, and end up stealing the cover off it and installing it on a new, Motorcraft regulator ....
JMHO, John
Offline preaction
« Reply #8 on: September 20, 2019, 08:21:06 PM »
Is Midlife talking about Midlife in the 3rd person ?
« Reply #9 on: September 20, 2019, 09:25:55 PM »
No, Midlife was talking about Midlife the car (1966 GT fastback).  When he talks to himself, an argument immediately ensues, so that's a no-go.  Shut up, you twit...I told you twice already.  No...you shut your pie-hole!
*sigh*
« Reply #10 on: September 21, 2019, 12:11:23 AM »
No, Midlife was talking about Midlife the car -
An object lesson is presented, you should have identified the car as such, "Midlife, the car". (Reminiscent of "My Mother, The Car" - naw.)
Offline Mike_B_SVT
« Reply #11 on: September 24, 2019, 03:11:10 PM »
*sigh*
Heh...
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline 1967 GT
« Reply #12 on: September 24, 2019, 09:43:52 PM »
I had the same issue in my SW under dash gauges. I purchased a NAPA solid state unit and used my Dremel with a drum sander to shape the resin encasement until the reproduction cover was able to fit the regulator. No more erratic needle operation on the ammeter gauge.
Offline CCP
« Reply #13 on: September 25, 2019, 08:53:38 AM »
  I did go with the solid state one. Works perfect.
1968 Shelby GT500KR
« Reply #14 on: September 25, 2019, 12:52:48 PM »
I wanted to caution that the extra work of converting to electronic insides to your previously mechanical regulator are wasted if you are converting a poor reproduction IMO. If you are going to the effort then it makes the most sense to convert something that is correct looking on the outside to begin with IMO. Some repro mechanical regulators have a incorrect base or a incorrect or poorly executed stamp on the cover . If you don't know the difference it would be prudent to find out what you don't know before wasting your time IMO. Of course as I mentioned before some vendors offer a regulator with correct base and nicely done cover with electronic insides that are nominally priced .
