Author Topic: 67 GTA 390 Coil and leaf spring markings  (Read 1622 times)
Offline brennancarey
« on: September 01, 2019, 07:00:03 AM »
Hi
I am looking for help on what paint markings I need to apply to my 67 GTA 390.
1. Front coil spring markings
2. rear leaf sorting markings.
Attached is the code I found on the Leafsprings.
C7ZA55556AE
257E6
thks
67 GTA 390 Fastback
Dark Moss Green
Dearborn
Build Date 12/28/66
Re: 67 GTA 390 Coil and leaf spring markings
« Reply #1 on: September 01, 2019, 10:18:54 AM »
Several coil springs were available depending on options on your car. If you have a Marti Report please attach it so we can tell which springs are appropriate. Or list every option that the car has.
Hi
C7ZA55556AE
257E6
thks
« Reply #2 on: September 01, 2019, 10:39:39 AM »
Ok thank you, pls see attached Marti report
67 GTA 390 Fastback
Dark Moss Green
Dearborn
Build Date 12/28/66
« Reply #3 on: September 01, 2019, 10:01:33 PM »
For the C7ZA-AE rear springs did you happen to try the search feature?  There is a 4 page  48 post thread that you might consider
Just used the words "67 rear spring markings"
We don't know all of the markings (haven't been confirmed) so some of them are a maybe. You can always leave them off right now since they are easy to add later
http://www.concoursmustang.com/forum/index.php?topic=17385.0
Based on an early 67 GT Fastback, automatic, PS and no AC buildsheet it shows
- 1 Yellow and 1 Tan on the front springs (brushed out of the car sitting on its side or upside down)
- 1 Orange and 1 White  stripes on the rear end of the short leaf
Now here is where the confusion begins. The chart you will find in the thread above shows the C7ZA-AC as being confirmed from a 67 390 Fastback buildsheet from most likely the NJ plant with a projected build date of 12/2/66 about 2 weeks prior to you example.  Not sure how the confirmation was made unless Paperback Writer, the OP, saw the car/springs that went with the buildsheet. His chart shows a silver and green stripe.
Buildsheet info posted above is from a 67 390 Fastback, (GT, Auto, PS, Nno AC) buildsheet from NJ  with a projected build date 06A. A couple of weeks after your cars projected date.
At this point, assuming that the AC and markings were confirmed from a set of original springs that is the best choice now IMHO.  This is one of the reasons I prefer to match spring identification rather than the buildsheets when it comes to only these parts. Seen to many mismatches
Paint mark info isn't always easy to come by and many of us have been studying it for years. Consider that if you put on an incorrect mark it will likely be copied dozens of time from others assuming that you knew what the mark should be and will rely on you that you were certain it was.
« Last Edit: September 02, 2019, 04:43:40 PM by J_Speegle »
