Author Topic: Convenience pack 1970 mach1  (Read 885 times)
Offline Brisbane
« on: August 31, 2019, 09:42:21 AM »
How was the seat release wiring routed to the seat?
« Last Edit: September 01, 2019, 10:13:07 PM by J_Speegle »
Re: Convenience pack
« Reply #1 on: August 31, 2019, 03:42:50 PM »
As mentioned in the FAQs it will be helpful - long term - if you insert your car information into your signature so it is always present when you post a question. At this point we have no idea of what year (got the plant by where you initially posted the thread) your asking about and that will be important to anyone trying to help you
Guessing your asking about a 70 but many here have a car, multiple cars or ask questions about details from a different year than their typical focus so production date and plant really help out
Offline 70cj428
« Reply #2 on: September 01, 2019, 12:49:13 PM »
There's a lower harness that plugs into the main convenience group harness behind the right kick panel. it runs across the floorpan and has plugs for the seat solenoids just under the outer seatback hinge. Each seat has a small harness at the outer seatback hinge that plugs into the solenoid in the seat back. If you have the "Electrical" assembly manual there's a page that shows everything ….
Hope this helps, John
Offline Brisbane
Re: Convenience pack 1970 mach1
« Reply #3 on: September 01, 2019, 01:47:06 PM »
Thanks , the wires have been poked through the vinal side of seat base.
I'll  look for wiring plans.
« Reply #4 on: September 01, 2019, 10:19:36 PM »
Hope these help. Looks like it runs from the passenger side kick panel - to the seat riser - then across
