Author Topic: 1970 mach1 Suspension paint mark help  (Read 2064 times)
Offline Brisbane
« on: August 30, 2019, 07:30:14 PM »
Looking for painting colour / colours for front end and rear end suspension components  and steering gear. Thanks
« Last Edit: April 21, 2025, 06:37:58 PM by J_Speegle »
Re: 1970 mach1
« Reply #1 on: August 31, 2019, 12:26:37 AM »
First welcome to the site. Hope you find the support and information your need for your restoration needs
We've done this a number of times in other threads but not for 70 Mustangs specifically (that I can recall)  so I've shared some of the basics below. Details above specific finishes (more in depth) can be found in other threads about suspension finishes and in the Library
To start out with none of the suspension items or steering is painted except for front sway bar. And you will find that natural finished is dependent (for the final look) on type of metal and how it was treated or handled after it was made (machined, heat treated, not treated .....)
Since you were specific to just suspension that keeps the list somewhat short so
Front suspension
Tie rods, idler arm, drag/center link, pittman arm,  strut rods, spindles - all heat treated (range of darker tones with lighter machined surfaces and backing insert for tire rods.
Tie rod adjustment sleeves - Bare steel
Strut washers - will have color coding to identify their application
Sway bar end links & mounting brackets - Natural steel
Upper control arms - Bare steel main bodies with plated boot retailer, dark heat treated inner mount and ends
Spring seats - Bare steel main body with bushing insert with heat treated center rod
Lower control arms - Dipped black inner 2/3 (approx - at the stut rod attachment holes or near by) with natural ball joint ends. Plated boot retainer and dark heat treated ball joint retaining plate
Coil springs - Dark heat treated bare steel with identification stripes applied with a brush
Sway bar - Painted semi gloss black
Shocks - Painted semi gloss black
Steering box - Bare cast main body with natural stamped steel cover/lid with dark heat treated retaining bolts. Zinc plated end plug and machined upper main body, details with zinc plated upper nut. Typically with a number of identification and inspection paint marks. Rag joint shaft and mating plate, bare stamped formed steel and hardened rod and weld detailing.
Rear Suspension
Rear leaf springs - Dark heat treated leaf springs, held together by natural (non-heat treated) bare steel clamps with rubber insulators and separated with black plastic insulators between some of the leaves. Rubber eye bushings are natural steel and rubber.
Shackles - Bare untreated steel with heat treated rods.
Shocks - Painted semi-gloss black
Rear sway bar - If so equipped - Bare heat treated steel is what I've seen MCA rules want semi-gloss black.
Rear spring to rearend  (shock plates) plates. Bare untreated stamped steel. Formed edges can be a little brighter due to the forming process
All parts oiled to reduce rusting. Kept the details somewhat general we can steer you to more details answers in thread that focus on just one of two items but thought this would get you started.  Of course some of this may come out in the follow up questions.
« Last Edit: November 26, 2019, 05:25:00 PM by J_Speegle »
Offline Brisbane
Re: 1970 mach1
« Reply #2 on: August 31, 2019, 10:18:39 AM »
Thankyou
Offline ExportMach
Re: 1970 mach1
« Reply #3 on: October 08, 2019, 01:28:45 PM »
Rear sway bar - If so equipped - Bare heat treated steel.
Not to quibble but this item is painted semi-gloss black according to MCA rules.
Mark C
Offline rare70cat
Re: 1970 mach1
« Reply #4 on: July 10, 2020, 01:48:36 PM »
Old thread but have a question about the front strut rod washer's color. I read in Mustang Monthly issue June 2, 1997 article " Ultimate Concourse Detailing" of Bob Perkins 1500 mile Boss 302. The strut rod front washer was painted per "TIRE" application. This Boss had F60 tires so the front strut washer was light blue. On Bob's 1970 B429 the strut rod washer is also light blue. So... Does anyone know or have any input on the color codes for the front strut rod washer's color. I have a 1970 Mercury Cougar convertible that came with "E78 x 14" tires.
Re: 1970 mach1
« Reply #5 on: July 10, 2020, 05:16:07 PM »
Typically the strut rod washer would be bare steel on your car. You can blast corrosion away with preferred method then tumble with a stainless steel media for IMO best look.Others will have their own way. Some will lightly phosphate so as to hold rust inhibitor better. You will need some kind of rust inhibitor if bare steel to prevent flash rust. If you use another faux finish make sure it looks close to the bare steel look.
Re: 1970 mach1
« Reply #6 on: July 10, 2020, 05:23:21 PM »
...... Does anyone know or have any input on the color codes for the front strut rod washer's color. I have a 1970 Mercury Cougar convertible that came with "E78 x 14" tires.
Ford/the assembly plants and providers didn't always mark every item for every application especially the standard or basic applications that included the majority of orders. This save time and dollars. Agree with Mr Gaines :) that for your application there would not be a marking to identify the tire or wheel combination so you can take it off your list.
Offline DaveF
Re: 1970 mach1
« Reply #7 on: April 21, 2025, 10:09:44 AM »
I too, am interested in getting more information about the colors on the Strut washers. My car came with F70-14 tires. Any info is appreciated.
1970 Mustang Mach One
428 SCJ w/Drag Pak 3.91
Metuchen plant
Built 9/5/1969
Re: 1970 mach1
« Reply #8 on: April 21, 2025, 06:41:29 PM »
Not all parts received paint identification markings especially ones that were pretty much "standard" parts. Guess it made sense for some suppliers to only pay to mark the exceptions, ones that were different from the standard parts, rather than all.  For example engine identification on bodies at some plants and years some engine combinations were not identified with markings since the vast amount of cars were built with those one or two combinations leaving the worker with that task to just have to marked the others and in some examples they even grouped a couple of engines together to save more time and effort.
