Author Topic: Tai light housing finish  (Read 2722 times)
Offline qman
« on: September 18, 2009, 05:14:16 PM »
What is the correct finish for a 67-68 tailight housing (the part you see when you look in the trunk)? It appears to be a zinc coating. Whatever the coating is can it be duplicated at home?  Thanks,
Offline Sunlitgold68
Re: Tai light housing finish
« Reply #1 on: September 18, 2009, 05:54:25 PM »
The outer most part is zinc dichromate (gold look), the inner part is zinc (silver).
I had mine replated but it looks shinier than it is suppose to.
8T01C204XXX
Built May 14th, 1968
« Reply #2 on: September 18, 2009, 08:18:22 PM »
67 is all clear zinc, 68 has the clear zinc and zinc dichromate finish.
« Reply #3 on: September 18, 2009, 08:31:30 PM »
You can use some of the rattle cans  Bright galvanized inside and Tank coating on the exterior but plating really isn't that expensive yet as long as you group all your needs to do at the same time or go together with a couple of friends to share the  cost
