Author Topic: 66-Oil pan plug  (Read 2238 times)
Offline GT350Lad
66-Oil pan plug
« on: August 24, 2019, 12:43:23 AM »
Hi guys, what oil pan plug was used on the 65/66 cobra oil pan? Was it the standard v8 one? And if so was it like this in my pic?
Cheers
« Last Edit: August 24, 2019, 05:58:57 AM by J_Speegle »
Re: Oil pan plug
« Reply #1 on: August 24, 2019, 01:55:19 AM »
Cheers
Standard bolt. That makers mark on the bolt does not look familiar .
Offline GT350Lad
Re: Oil pan plug
« Reply #2 on: August 24, 2019, 02:06:09 AM »
Ok thanks Bob, what should I be looking for in my box of 1000 bolts?
Cheers
Offline GT350Lad
Re: Oil pan plug
« Reply #3 on: August 24, 2019, 05:20:49 AM »
Found one, it’s just got a capital ‘A’ on it, correct?
Cheers
Re: Oil pan plug
« Reply #4 on: August 25, 2019, 12:57:22 AM »
Cheers
The typical one is plain no makers mark from what I have seen. The others you mentioned are original on various year sheet metal oil pans however . Most likely different oil pan mfg's used different sources for the bolts.
Offline GT350Lad
Re: 66-Oil pan plug
« Reply #5 on: August 25, 2019, 02:48:05 AM »
Thanks Bob, I’ll keep looking
Cheers
Offline Kingchief
Re: 66-Oil pan plug
« Reply #6 on: August 26, 2019, 04:21:35 PM »
A picture of an original one might help you in your search.  If anyone has one why not post it!
Good luck,
Steve
SFM 6S406
Re: 66-Oil pan plug
« Reply #7 on: August 26, 2019, 06:08:23 PM »
Good luck,
Steve
Not much to see given no markings on most that I have seen . Makes it kind of easy to find a replacement IMO.
Re: 66-Oil pan plug
« Reply #8 on: August 26, 2019, 06:16:56 PM »
Took a quick look through my pictures and could not find a clear picture handy. Believe you would likely modify the one you have by removing just the raised castings on the one you have.  Wil try and look in the garage to see if one of mine might have an original still in it
Offline GT350Lad
Re: 66-Oil pan plug
« Reply #9 on: August 26, 2019, 06:27:25 PM »
Thanks Bob and Jeff, appreciate it
