Author Topic: 66 289 oil pan date code  (Read 1199 times)
Offline kcodecoupe
« on: August 22, 2019, 08:49:48 PM »
I have a standard 289 oil pan with 31 66 2 stamped on the bottom, is this a date code, I know how to read the 69 70 oil pan dates , thanks
Re: 66 289 oil pan date code
« Reply #1 on: August 22, 2019, 10:15:17 PM »
Don't recall seeing that date pattern before and don't know where they were made but what you provided does not indicate a Ford stamping plant pattern we see on other sheet metal.
Could be decoded as Feb 31 1966
Offline kcodecoupe
« Reply #2 on: August 22, 2019, 10:31:56 PM »
Thank you for the input ,i did at first think that as a Feb date but as there are only 28 days in that month I ruled that out, I will glass bead it to see if there are more clues , was told it was from a west coast 66 mustang it still has factory blue paint on it,
« Reply #3 on: August 22, 2019, 10:42:10 PM »
Correct but we do see evidence of incorrect and mistake date code patterns but of course there woul dbe a whole bunch of them done incorrect to document the mistake
Offline steve_f
« Reply #4 on: August 23, 2019, 02:22:04 PM »
Looks like it could be a julian date code. 31st day of 1966 second shift maybe?
Steve
1965 (15S) San Jose Mustang GT Fastback (sold)
« Reply #5 on: August 23, 2019, 02:43:02 PM »
Possible
Offline kcodecoupe
« Reply #6 on: August 23, 2019, 09:45:18 PM »
I used zip strip paint remover for a better look, im going to go with   3 1 66 2  march 1st 1966 2nd shift,
Offline Dan Case
« Reply #7 on: August 24, 2019, 09:54:23 AM »
Older data point. The original oil pan for High Performance 260 engine serial number 137 installed into a new Cobra chassis long ago.
We read the stamping as January 1, 1962 second shift FoMoCo® which was a Monday I believe.
Dan
« Reply #8 on: August 24, 2019, 03:38:04 PM »
Spacing seems to have changed on the ingots they used - apparently leading to the confusion.
kcodecoupe if the pan is believed to be original how does the date on the pan compare to the rest of the engines part decoded as you have currently?
Offline kcodecoupe
« Reply #9 on: August 24, 2019, 04:23:05 PM »
I don't have the engine or engine parts that the pan was on originally , the car was used to make a 66 gt350 clone,    all I have from that car is the front suspension components.
