Author Topic: 66 Coupe Hazard Switch location?  (Read 2428 times)
Offline Tiny
« on: August 05, 2019, 08:17:09 PM »
Can you please advise re the correct location for the Hazard switch.  I thought that the swtich was located inside the glove compartment but I cannot see any holes where the switch should be mounted.  Currently its located under the dash but I dont think this is correct.  Can you please assst.
thanks
67 San Jose Built GTA 390 Coupe
C6, PS, A/C
Re: 66 Coupe Hazard Switch location?
« Reply #1 on: August 05, 2019, 08:24:34 PM »
It's mounted on the inside upper left top, near the front of the glove box. A 65 was mounted under the dash, as an option.
I strongly recommend you get a set of 66 Mustang Assembly Manuals, plus the 64-65 Chassis, and 64-65 Weld and Sealant manuals.
Offline OldGuy
« Reply #2 on: August 05, 2019, 08:25:02 PM »
You are correct that the switch should be located in the glove box. Your car probably has a '65 glove box insert installed which didn't have a glove box hazard switch.
Frank
Offline ChrisV289
« Reply #3 on: August 05, 2019, 08:47:37 PM »
When was the car built?
2009 V6 Mustang Coupe
Offline Tiny
« Reply #4 on: August 05, 2019, 11:58:13 PM »
Thanks Gentlemen, my 66 was built in September 65 and does have other 65 components on the car I have notice ie: engine mounts.  Could it be that as it was built in Sept 65 is the reason it is mounted under the dash or not?
Cheers
C6, PS, A/C
« Reply #5 on: August 06, 2019, 12:22:18 AM »
Here are some other examples from which should help up with an answer or at least some help
6R10255x Projected build date - 30H
6R1017xx Projected build date - 27H
6R1137xx  Projected build date - 30J
6R08A1174xx Projected build date - 07K
6R1222xx Projected build date - 21K
6R1271xx Projected build date - 03L  Apparently remounted  ::)
« Last Edit: August 06, 2019, 12:28:12 AM by J_Speegle »
Offline Tiny
« Reply #6 on: August 06, 2019, 12:31:32 AM »
Thankyou very much, really appreciate it.
Mark
C6, PS, A/C
« Reply #7 on: August 06, 2019, 01:54:32 PM »
There appears to be some possible wiring differences specifically in the power to the flasher between a 65 optional flasher and a 66 standard equipment flasher. The under-dash mounting may be a relocation of the standard 66 glove box mount.
Offline ChrisV289
« Reply #8 on: August 06, 2019, 03:38:16 PM »
