Author Topic: 9" Rear Axle Housing "J" Brake Line Tab Replacement  (Read 1001 times)
Offline Snydly289
« on: August 04, 2019, 11:39:13 PM »
Hi all,
I am currently restoring my 65 K 9" axle housing and I need to replace a broken brake line "J" tab keeper. Is there a vendor that makes these weld on tabs like the original or am I going to have to rob one off of another axle housing?
Riley
65 K Code Fastback -5F09K325XXX, Oct. '64, Vintage Burg, Rally Pac, Arvinode Exh, lots '64 items
66 A Code GT Coupe -4 speed, bench Seat, P/S, A/C, Rally Pac, handling package, 8 track
66 A Code Fastback -Built 302, 66 S2MS Intake, WC T-5, 4-wheel Wilwoods, locking 9"
66 T Coupe
65 T Code Fastback
Re: 9" Rear Axle Housing "J" Brake Line Tab Replacement
« Reply #1 on: August 05, 2019, 03:09:47 PM »
Make one or rob one from another. It is not a common thing to have to be replaced. That is probably the main reason why they are not typically available from main stream vendors.
« Reply #2 on: August 05, 2019, 04:18:38 PM »
Another option is to make your own out of standard strip of metal using the other as a pattern. Likely best to drill a hole and plug weld it then grind and dress the surface
Offline Snydly289
« Reply #3 on: August 07, 2019, 05:33:34 PM »
Thanks for the replies guys, looks like I'll try to carefully rob one off of my 8" axles in my ever growing "parts pile"
Riley
66 T Coupe
65 T Code Fastback
