Author Topic: Neutral Safety Switch - Remove  (Read 573 times)
Offline ChrisV289
« on: August 03, 2019, 05:26:25 PM »
Question on wiring which Midlife and others will be able to answer.  The car was originally a 4 speed, then a C4 was installed, and now an AOD. I am putting a 4 speed back in.  I assume I remove the neutral safety switch harness but what goes in its place or what is hooked up so the car will start?
2009 V6 Mustang Coupe
Re: Neutral Safety Switch - Remove
« Reply #1 on: August 03, 2019, 06:24:53 PM »
A jumper harness/connector that usually includes wiring to go down for the reverse lights (when applicable).
Offline ChrisV289
« Reply #2 on: August 03, 2019, 07:00:00 PM »
Car didn’t come with reverse lights
« Reply #3 on: August 03, 2019, 07:03:37 PM »
The 65 Mustang Electrical Assembly Manual has wiring diagrams.
Offline ChrisV289
« Reply #4 on: August 03, 2019, 07:15:23 PM »
Looking at that now Jim. Can it be that simple though?
« Reply #5 on: August 03, 2019, 08:07:07 PM »
Simple - yes. It's how you do it that complicates things. I won't get into details, but the first place I would look is a schematic.
« Reply #6 on: August 03, 2019, 09:35:37 PM »
Inside the passenger compartment just before the engine gauge feed plug goes through the firewall, there will be a male and female bullet plugs with red/blue wires on the underdash harness.  These connect to the NSS/BU harness if automatic and backup lights.  For a manual car, simply mate the male and female bullet plugs together on the underdash harness.  For manual cars with backup lights, a separate backup light harness without NSS was used, but stayed in the passenger compartment until exiting near the shifter hole in the tranny tunnel.
Offline ChrisV289
« Reply #7 on: August 04, 2019, 12:53:05 AM »
Thanks!
