Author Topic: How do I repair my water pump?  (Read 610 times)
Offline 66RavenGTCoupeAgain
« on: August 02, 2019, 08:27:51 PM »
Hi Guys,
I have an original aluminium pump on my Oct 64 built SJ 289 that needs the seal replaced. I will also replace the bearing while I'm at it even though it has no "play". I like to research this kind of thing before I start pulling things apart to see if I can tackle it myself. I have never done one before and don't think that there is much to it but would like to see a video or pictures of whats required but can't seem to find anything. Any help would be appreciated.
Thanks.
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Offline KevinK
Re: How do I repair my water pump?
« Reply #1 on: August 02, 2019, 08:41:33 PM »
I’m sure it can be done but you will need a press to remove the impeller and the shaft. Most people send them to a respectable water pump rebuilder. Several have been mentioned here.
MCA #33800, Gold Card 3rd Gen
BAMA Member
Offline outlawincorporated
  • Kangaroo Herder
« Reply #2 on: August 02, 2019, 09:32:17 PM »
DANIEL.
just get it rebuilt by a professional, one less thing to concern yourself about....
the chances of you doing more damage than good.
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
« Reply #3 on: August 04, 2019, 08:46:52 PM »
Hey Phil,
Joe Borg is doing it for me and has done plenty of them in the past. Just trying to get the seal. Do you know where I may be able to get one? (I'm in Australia guys)
« Reply #4 on: August 04, 2019, 11:00:59 PM »
Hey Phil,
I think NPD or dead nuts on sells the bearing and seal kits for DIY.
« Reply #5 on: August 04, 2019, 11:44:13 PM »
Thanks Bob,
I managed to find a bearing and seal 15 minutes away from where I work in the end.
