Author Topic: Rubber Battery Post Shield - Dec 65 SJ  (Read 893 times)
Offline KenFirch
« on: August 02, 2019, 06:03:32 PM »
I see the replacement rubber battery post shields are available with the 4 rivets from various vendors, but where can you get those thick staples that were used?  It looks like they are 3/8" wide versus the 1/2" wide ones used on the splash shields.  I guess I'll just fold them over from the back since I ain't got one of those staple guns that go through steel.   ;)
Car is 66 SJ convert with scheduled build date of 12/6/65.  Panel date code is 12/15.
« Last Edit: May 25, 2020, 06:41:43 PM by J_Speegle »
Current Project: 66 Mustang Convert (6R08A140031 - 12/6/65 Date)
Past: Owner of SFM6S524 1980-2015.
Re: Rubber Battery Post Shield
« Reply #1 on: August 02, 2019, 09:59:32 PM »
Back around 2000, the plastic push-in pins were available.  I probably got them from CJ Pony or NPD at the time...
« Reply #2 on: August 03, 2019, 12:15:27 AM »
- where can you get those thick staples that were used?
Measure the diameter of one of your existing staples, find a roll of safety wire the same diameter and make some. I did that for the splash shields as the staples supplied in the aftermarket rubber shields were 0.062in dia and the originals were 0.047 in dia.
« Reply #3 on: August 05, 2019, 05:05:48 AM »
+1 Done it many times for different needs/applications
Offline KenFirch
« Reply #4 on: August 27, 2019, 01:43:24 PM »
Ended up getting the "Skirt Staple Kit" #T27986S from Larry's Thunderbird, perfect fit.  3/8" wide, .060 x .055 rounded rectangle shape.  Did shorten the legs a bit.
