Author Topic: 67 Battery Discussion -  (Read 2983 times)
Re: 67 Battery Discussion -
« Reply #15 on: July 27, 2019, 06:49:08 PM »
Looks like a task to go through a bunch of buildsheets with attention to battery, alternator, ac, GT option is in order to at least collect base information to move forward.
Did I miss something?
« Reply #16 on: July 27, 2019, 07:11:21 PM »
Yes you were elected.
« Reply #17 on: July 27, 2019, 07:12:37 PM »
Was this a hand count or another secret ballot?   ::)
Offline Texas Swede
« Reply #18 on: July 27, 2019, 08:16:41 PM »
67402F7A 01317 came with heavy duty battery as per Marti report and the Z bracket.
Texas Swede
« Reply #19 on: July 27, 2019, 10:07:49 PM »
Worse: election interference by unindicted co-conspirators...
« Reply #20 on: July 28, 2019, 02:14:17 PM »
Here a bit of battery information from the 68 electrical assembly manual.
No mention of up grade to a HD battery there for AC.
Offline preaction
« Reply #21 on: July 28, 2019, 04:30:57 PM »
That's the info right there 45 amp hour for a 390 with standard trans which is what the build sheet was that I posted though it appears the amp hour went up with the A/C option IIRC means more plates in the battery case and maybe the heavy duty designation.
Offline preaction
« Reply #22 on: July 29, 2019, 10:08:48 PM »
It looks like I typed to quickly as Marty stated no mention of A/C upping the battery used from the picture posted. Its interesting why an automatic transmission would get a higher rated battery.
« Reply #23 on: July 29, 2019, 10:18:28 PM »
Could be that the original owner specified/paid for it. Would need to see a bigger sampling to see if this was standard or not.
« Reply #24 on: July 30, 2019, 12:35:53 AM »
I thought the same thing.
 I guess when your battery is dead in a manual you can jump start it, you can't in a automatic. LOL
« Reply #25 on: July 30, 2019, 01:45:53 PM »
I think Marty is correct.
In the later 60s GM stopped putting rear hydraulic pumps in their Powerglides.
Without a rear pump you cannot push start an automatic.
Ford's Fordomatic/Cruiseomatic through the early 60s could as well. I don't believe any C4 had a rear pump.
I remember push starting a 63 or 64 Impala with a Powerglide. The rear pump is connected to the driveshaft via the output shaft which makes it possible to build hydraulic pressure by pushing the car.
Offline Paperback Writer
« Reply #26 on: July 30, 2019, 02:21:22 PM »
Here’s some Marti Report information...
I’ve got copies of 13 Marti Reports for cars with the Heavy Duty Battery option.
They break-down as follows:
Dearborn
1967 390-4V Mustang GT Fastback – With A/C, build date = 3/15/1967
1967 390-4V Mustang GT Convertible – No A/C, build date = 4/17/1967
1967 289-2V Mustang GTA Fastback – No A/C, build date = 7/12/1967
1967 289-4V Mustang GTA Convertible – No A/C, build date = 8/2/1967
San Jose
1967 289-4V Shelby GT350 Fastback – No A/C, build date = 3/22/1967
1967 428-4V Shelby GT500 Fastback – No A/C, build date = 4/13/1967
1967 289-4V Shelby GT350 Fastback – No A/C, build date = 5/4/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 5/8/1967
1967 289-4V Shelby GT350 Fastback – No A/C, build date = 6/7/1967
Metuchen
1967 390-4V Mustang GT Fastback – No A/C, build date = 1/5/1967
1967 289-2V Mustang (T5) GT Hardtop – No A/C, build date = 2/22/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 3/9/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 5/26/1967
FYI – The Marti Reports do not include Alternator information.  Other than these cars all being GT/GTA/Shelbys, there doesn’t seem to be a correlation to any other options.
That being said, I have copies of Marti Reports for another 42 GT/GTA cars, and they do not have the Heavy Duty Battery option.
(Of them, 14 also had Air Conditioning)
Dearborn
1967 390-4V Mustang GTA Fastback – With A/C, build date = 12/15/1966
1967 390-4V Mustang GT Fastback – No A/C, build date = 12/28/1966
1967 390-4V Mustang GTA Fastback – With A/C, build date = 1/24/1967
1967 390-4V Mustang GT Fastback – With A/C, build date = 2/21/1967
1967 390-4V Mustang GTA Hardtop – No A/C, build date = 2/25/1967
San Jose
1967 390-4V Mustang GTA Fastback – With A/C, build date = 8/22/1966
1967 390-4V Mustang GTA Convertible – No A/C, build date = 9/22/1966
1967 390-4V Mustang GT Fastback – No A/C, build date = 9/28/1966
1967 390-4V Mustang GTA Fastback – No A/C, build date = 10/3/1966
1967 390-4V Mustang GT Hardtop – No A/C, build date = 10/27/1966
1967 390-4V Mustang GTA Convertible – No A/C, build date = 11/10/1966
1967 390-4V Mustang GTA Fastback – With A/C, build date = 11/12/1966
1967 390-4V Mustang GT Convertible – No A/C, build date = 11/15/1966
1967 390-4V Mustang GT Hardtop – No A/C, build date = 11/30/1966
1967 390-4V Mustang GTA Fastback – No A/C, build date = 12/13/1966
1967 390-4V Mustang GT Fastback – No A/C, build date = 12/20/1966
1967 390-4V Mustang GTA Fastback – With A/C, build date = 12/21/1966
1967 390-4V Mustang GT Fastback – No A/C, build date = 12/29/1966
1967 390-4V Mustang GTA Hardtop – With A/C, build date = 1/9/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 1/11/1967
1967 390-4V Mustang GTA Convertible – With A/C, build date = 1/31/1967
1967 298-4V Mustang GT Fastback – No A/C, build date = 4/20/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 4/20/1967
1967 289-4V Mustang GTA Fastback – With A/C, build date = 5/2/1967
1967 298-2V Mustang GTA Hardtop – No A/C, build date = 5/9/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 5/17/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 8/2/1967
1967 390-4V Mustang GTA Hardtop – No A/C, build date = 8/3/1967
Metuchen
1967 390-4V Mustang GT Hardtop – No A/C, build date = 9/19/1966
1967 390-4V Mustang GTA Fastback – With A/C, build date = 9/29/1966
1967 289-4V Mustang GT Convertible – No A/C, build date = 11/28/1966
1967 390-4V Mustang GTA Hardtop – With A/C, build date = 12/3/1966
1967 390-4V Mustang GT Fastback – No A/C, build date = 1/24/1967
1967 390-4V Mustang GTA Fastback – No A/C, build date = 1/26/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 4/2/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 4/5/1967
1967 390-4V Mustang GT Fastback – With A/C, build date = 4/20/1967
1967 390-4V Mustang GTA Fastback – With A/C, build date = 5/2/1967
1967 390-4V Mustang GTA Convertible – No A/C, build date = 5/9/1967
1967 390-4V Mustang GT Convertible – No A/C, build date = 5/15/1967
1967 390-4V Mustang GT Fastback – No A/C, build date = 7/18/1967
1967 390-4V Mustang GT Convertible – With A/C, build date = 7/28/1967
Hope this information helps!
Kevin
« Last Edit: July 30, 2019, 02:23:29 PM by Paperback Writer »
1967 390 GTA Convertible
7R03S110###
« Reply #27 on: July 30, 2019, 03:06:22 PM »
Is it just me, Kevin's findings of cars listed WITH H.D. battery option are all after January, 67?
Odd that none show up for August 66 thru December...
« Reply #28 on: July 30, 2019, 04:19:39 PM »
Yep - I noticed that too.  That's the reason I included the build dates...
It would be interesting to see the Marti Reports for some of the early Shelby GT500's/GT350's built in the Sep - Dec 1966 time frame...
(Unfortunately, I don't have any copies in my collection).
I take that back - I do have a Marti Report for the Shelby GT500 Convertible, built on 11/21/1966.
It does not list the Heavy Duty Battery option.
« Last Edit: July 30, 2019, 04:33:33 PM by Paperback Writer »
7R03S110###
« Reply #29 on: July 30, 2019, 05:13:38 PM »
I am not sure but think that the battery apron might have been changed on that car. I don't remember the car ever having the extra bracket . Unfortunately If the apron was changed any evidence for or against the bracket would be lost .
