Here is a picture of a 67 Mustang with a heavy duty battery (red caps show darker then yellow in B+W) that apparently doesn't have the extra bracket. It is a very loaded option car with A/C and Cruise. It must be a early production given the January of 67 Car Life magazine it was featured in.Car Life - Jan_ 1967 - Page 38 (Zoom).jpg
7R02K146xxx 2/2/67 SJ has hole in apron:
Also note placement of Pass. side horn on condenser bolt. Typically mounted in its own set of holes with horn opening facing down.
Bob, I was referring to the passenger side horn. The driver's side has the special bracket.
Interesting looking heat shield, I have not seen one like that.
At the risk of contaminating this survey with a Metuchen data point, my signature car has the hole and the build sheet indicates a "45" at Battery Amperage boxes 40 and 41. I am not sure if that is the standard or heavy duty battery. If you know, can you please advise?I too would be interested in the dimensions of this bracket.Thanks,Mark
