Author Topic: Repairing Convertible Crossover Plate Achor Nuts  (Read 975 times)
Offline NEFaurora
« on: July 21, 2019, 01:42:16 PM »
NOTE: This string of posts was separated from a discussion related to the convertible floor cross over plate installed on convertibles
Since we are on the subject...
Anyone know the best method of how to remove/replace a stripped crossover plate nut???....just so I can get the damn thing out......?
:o)
Tony K.
« Last Edit: July 23, 2019, 12:06:03 AM by J_Speegle »
MCA#70001
Re: Repairing Convertible Crossover Plate Achor Nuts
« Reply #1 on: July 21, 2019, 02:17:54 PM »
Have you considered a helicoil? Just a thought.
« Last Edit: July 23, 2019, 12:06:11 AM by J_Speegle »
Offline NEFaurora
« Reply #2 on: July 21, 2019, 07:09:55 PM »
I would, but I can't get to it from behind....!
:o)
Tony K.
« Last Edit: July 23, 2019, 12:06:18 AM by J_Speegle »
MCA#70001
« Reply #3 on: July 21, 2019, 08:44:18 PM »
Why would you need to get to the back side?
« Last Edit: July 23, 2019, 12:06:30 AM by J_Speegle »
« Reply #4 on: July 22, 2019, 12:24:35 AM »
Helicoils are installed just like a bolt would be.
« Last Edit: July 23, 2019, 12:06:37 AM by J_Speegle »
« Reply #5 on: July 22, 2019, 04:07:20 PM »
I believe the captive nut on the backside may have broken loose?
Is the spinning nut next to the seat plug? If so maybe you can grab the spinning nut with a distributor wrench. Think about it ...
Even if you get the bolt and the now un-captive nut out you won't have a way to get another nut back in there and make it captive again.
You may have to perform a little surgery on the side of the box with a cutoff wheel, repair the nut issue by welding in a new one and reweld it all back together.
I don't have first hand knowledge of the convertible issue, but it is the way I've fixed other captive nuts breaking loose.
« Last Edit: July 23, 2019, 12:06:44 AM by J_Speegle »
Offline NEFaurora
« Reply #6 on: July 22, 2019, 10:22:18 PM »
"I believe the captive nut on the backside may have broken loose?"
Bingo!
Now what....
:o)
Tony K.
« Last Edit: July 23, 2019, 12:06:51 AM by J_Speegle »
MCA#70001
« Reply #7 on: July 23, 2019, 12:03:47 AM »
If you can fish it out put a long bolt in it (to hold it in place with one hand. Put it back in place and while holding it tack weld it back in place carefully
Another choice (not sure if they are made that large) find an insert nut, put it in the hole, expand it until its real tight and your good. Just like they inserted the PS bracket anchors in the frame rail and other places on a smaller scale.
« Last Edit: July 23, 2019, 12:07:00 AM by J_Speegle »
Offline rrenz
« Reply #8 on: July 23, 2019, 10:09:38 PM »
That was going to be my suggestion. I would do as Jeff just explained. A nutsert would work well here assuming they make one that large. I believe northern tool carries a good selection of those.
« Last Edit: July 23, 2019, 10:12:36 PM by rrenz »
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
« Reply #9 on: July 23, 2019, 11:09:45 PM »
These are squish inserts like the hood hinge mounts.  I don't know the exact term (I'm sure Jim does).  I bought some a while back, but they are slightly different from originals.  Doesn't really matter on the support brace as the inserts can't be seen once everything installed.
Offline mgmradio
« Reply #10 on: July 24, 2019, 12:48:17 AM »
They are called rivet nuts.
Offline NEFaurora
« Reply #11 on: July 27, 2019, 09:22:13 AM »
Charles, Any source on those nuts??  McMaster-Carr????
:o)
Tony K.
MCA#70001
Offline mgmradio
« Reply #12 on: July 27, 2019, 10:51:33 AM »
McMasters and Carr have them , just look up rivet nut.
