Author Topic: Door Handle buttons  (Read 3398 times)
Offline Sunlitgold68
Door Handle buttons
« on: September 16, 2009, 11:36:59 AM »
are the reproduction door handle buttons any good? Is it better to find some OEM ones?
8T01C204XXX
Built May 14th, 1968
Re: Door Handle buttons
« Reply #1 on: September 16, 2009, 04:25:15 PM »
The last reproduction ones I used, the pin was not attached to the button.  Which means the button can be moved around with your thumb once in the handle.  Very annoying and detracts from the overall quality of a restoration.
I would recommend buying NOS or having an original pair re-chromed.  I think my chrome guy only charged like $25 each to do them.
Offline rockhouse66
« Reply #2 on: September 16, 2009, 07:58:14 PM »
I swapped my original buttons into the repro handles, which improved them, but still not as good as an original as Charles suggested.
'66 GT FB
Offline JKWilson
« Reply #3 on: September 16, 2009, 10:42:46 PM »
Charles, if you don't mind my asking, and not to get off topic, but is your chrome plater the same folks that did your other plating (Surtronics)?
« Last Edit: September 17, 2009, 12:29:45 AM by JKWilson »
« Reply #4 on: September 16, 2009, 10:49:18 PM »
Found a pair of NOS button kits, thanks
8T01C204XXX
Offline s2ms
    • 6S1757 Info
« Reply #5 on: September 16, 2009, 11:03:05 PM »
One thing to look out for when rechroming is the show quality triple plating may make them a little "wider" than OE and cause them to bind in the handle. At least mine did that, seems the tolerances are pretty tight.
« Reply #6 on: September 17, 2009, 12:52:32 AM »
Surtronics doesn't do any chrome plating.  I use Qual-Krom for that.
Regarding re-chrome of the buttons, haven't had any problems with chrome build-up on the tangs.  Could use a file to smooth them off if it was an issue.  Have seen service replacements that the tangs were about half the size of the originals.  Even in the old FoMoCo boxes.
