Author Topic: Shock Tower - 67 San Jose - Cowl braces fixation bolts + nuts finish  (Read 622 times)
Offline Fastback2013
In attachment picture of 4 bolts + nuts for the fixation of the shock tower braces to the cowl.
I hope that I am explaining it correctly?
In the Osborne assembly manual I couldn't find a description for that hardware and couldn't find an answer here in the search function?
Any help would be appreciated for confirming the correct finish for the bolt and the nut.
Thanks in advance for your time and effort.
Kind regards,
Jeroen
« Last Edit: July 15, 2019, 05:16:46 PM by J_Speegle »
San Jose 7R02C1708xx
Fastback GTA
built on 01/12/1967
Re: Shock Tower - Cowl braces fixation bolts + nuts finish
« Reply #1 on: July 15, 2019, 02:07:43 PM »
The bolts are zinc dichromate and the nuts are Phosphate and oil. AMK sell them for less than you can have them plated.
« Reply #2 on: July 15, 2019, 05:31:44 PM »
What head markings/supplier is on the AMK supplied ones?
BTW Fastback2013 changed the title to reflect what I believe was your focus as far as year and plant ;)
Re: Shock Tower - 67 San Jose - Cowl braces fixation bolts + nuts finish
« Reply #3 on: July 15, 2019, 06:49:26 PM »
Kind regards,
Jeroen
Did you look in the forum's library? Look under "Mustang Hardware Spreadsheet 67-68". You will find the answers to the immediate question plus more.
Offline BKnapp
« Reply #4 on: July 15, 2019, 07:11:20 PM »
+1...Jim’s spreadsheet is awesome! I would highly recommend downloading it if you are going to be addressing multiple fasteners. It is much easier than hunting through the Osborn manuals, although I do frequently cross check them.
