OK I checked the battery last night and it has a white case with MOTORCRAFT on the side and a black top. There is a numbner on the case and a tag below some yellowed plastic. The headlamps are SYLVANIA HALOGEN and the metal buckets are attached to them with the stainless ring. Three of the 4 plastic adjustment screws have been located. I also have the factory installed air filter element with a silk screened part number, some paper tags i lifted off because I didn't allow the dealer to prep it, plastic sheets with writing that they are to be removed upon delivery to new owner(off carpet i believe), paper tags for an auto lockout of reverse in english one one side and french on the other. One original windsheild wiper, the seat belt clip (but I'm not sure about that one as its got a wierd ford part number) and one front turn signal indicator housing but it has a cracked edge so it might let moisture in.
