Author Topic: Power steering control valve spool  (Read 2070 times)
Offline must69
« on: July 12, 2019, 11:34:19 AM »
I am rebuilding the P/S valve on my 69 Mach 1.  I noticed that the spool is available from aftermarket suppliers.  How often do these wear out?  Mine has some wear marks, and curious if this will affect performance and if it should be replaced.
Offline 69bossnut
    • DSD Restorations LLC
Re: Power steering control valve spool
« Reply #1 on: September 12, 2019, 06:07:13 AM »
From my experience as long as there is no pitting or burrs/gouges on it from wear. Make sure it moves freely in the bore. Then you are good to reuse.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
Offline must69
« Reply #2 on: September 12, 2019, 09:03:31 AM »
Thanks Dave.  I used the original and it works fine.
Phil
