Author Topic: Vacuum Advance  (Read 2792 times)
Offline ChrisV289
Vacuum Advance
« on: July 05, 2019, 06:13:05 PM »
Curious what others are doing as looking on the web and eBay I only see vacuum advances with the nipple to run a hose and not be able to change it out to end to accommodate the metal line fitting. Figure ask now so down the line I know where I need to go.
2009 V6 Mustang Coupe
Re: Vacuum Advance
« Reply #1 on: July 05, 2019, 07:35:00 PM »
Welcome to "we ran out" land. The original Motorcraft vacuum diaphragm had a stock number of DD-190, and a Ford service stock number of C5AZ-12370-A. They were the threaded fitting type for a metal tube. Ford, in it's infinite wisdom, replace that type with a rubber hose fitting type (there is a hex socket adjustment inside the fitting), but kept the same identification numbers. Remember, all Ford care about is will "it" work", the were not building Concourse Grade Cars.
The diaphragm sometimes can be repaired. Look in the Library in the 66 section. This repair does not address a shiny diaphragm housing. I've wire brushed a few, but they look wire brushed. Eastwood sells several "paints" that give a better look. As far as I can tell, nobody provides a diaphragm rebuild service like Fred Ballard does with fuel pumps. There's where we are today.
Re: Vacuum Advance
« Reply #2 on: July 05, 2019, 07:49:30 PM »
Offline ChrisV289
Re: Vacuum Advance
« Reply #3 on: July 05, 2019, 08:03:56 PM »
Try here: http://428cobrajetcars.com/new_parts
Is he still around?  Top of his page says closed until further notice...
Re: Vacuum Advance
« Reply #4 on: July 05, 2019, 08:17:27 PM »
believe he is still selling parts only. someone either here or on another board recently reported a successful purchase.
Re: Vacuum Advance
« Reply #5 on: July 05, 2019, 09:44:26 PM »
True
I purchased from him in March, another member in about May, also noticed the "closed" marker in both of those time frames.
Re: Vacuum Advance
« Reply #6 on: July 05, 2019, 10:57:20 PM »
I bought a vacuum advance from him earlier this year through the SAAC forum. He goes by DIZZY on that forum. He can be difficult to converse with.
Re: Vacuum Advance
« Reply #7 on: July 06, 2019, 10:27:58 AM »
He is still restoring distributors, but will tell you up front it could take months to complete.  He has some personal/family issues going on.
Offline rrenz
Re: Vacuum Advance
« Reply #8 on: July 08, 2019, 08:09:51 PM »
I buy one every time I see one. Currently I'm up to 2 in my vast collection. I found a NOS one at a car show a few years ago and then another still attached to a Dizzy. I found thats a little easier way to find used ones atleast. Search for old distributors. sometimes you can find one with the original advance still attached.
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Offline Hipo giddyup
Re: Vacuum Advance
« Reply #9 on: July 09, 2019, 11:09:53 AM »
+1, and its a part that seldom goes bad, at least in what I have found.. Now replating is another story.  ::)
Re: Vacuum Advance
« Reply #10 on: July 09, 2019, 05:09:41 PM »
Bits and pieces that I have.  Some match Jim's descriptions, above, others not so much ?  Don't seem to be any ID numbers anywhere ?  Brian
Re: Vacuum Advance
« Reply #11 on: July 10, 2019, 11:13:10 AM »
And of course the springs and washers within the advance unit help denote the "curve" for distributors based on their application, automatic, manual, etc...
Re: Vacuum Advance
« Reply #12 on: November 27, 2020, 05:50:25 PM »
Trying to clean up the workbench and found these hanging around. Application unknown.
Both have screw on adapters.
The blue one is marked AUTOLITE 12378 and the uncolored version has the same number but no AUTOLITE. I presume the non-AUTOLITE is the Motorcraft version?
As you can see, the blue one could be converted to screw in using the other adapter.
Interestingly my 65 289 A-code engine has the screw on hose adapter, so it could be a later Motorcraft.
Offline 10w30dna
    • Tim O'Connor Distributor Restoration
Re: Vacuum Advance
« Reply #13 on: December 03, 2020, 07:16:47 PM »
The C5AZ 12370 A services both metal line and rubber hose(nipple) as the parts are swapped into the service housing. ( 66/up only,pre 65 used a different part B9AF )I will be re-entering the distributor restoration very soon,but service will be a bit slow. ( I lost 50% of my help )Thanks for kind words. Tim O’Connor
« Last Edit: December 03, 2020, 07:22:20 PM by 10w30dna »
44 years as Ford dealer technician,retired.Favorite toys:'67 Fairlane drag race car. 10.40 @ 129 mph 1.40 60 ft. Current resto project: '68 Shelby GT 350 conv w/Paxton Supercharger .
Offline rockhouse66
Re: Vacuum Advance
« Reply #14 on: December 03, 2020, 07:28:21 PM »
That's good news Tim.  I have a couple vacuum advances to send you when the time is right.
'66 GT FB
