Author Topic: Water Pump  (Read 683 times)
Offline pstone
Water Pump
« on: June 21, 2019, 06:25:27 PM »
Can anyone tell me if this is an original water pump cast in 1965 or if the is factory replacement cast at a different time?  Is the FOMOCO stamp correct for a 1965 June thru August casting?
Re: Water Pump
« Reply #1 on: June 22, 2019, 08:32:06 AM »
According to Mannel's "Small Block V8" book the switch from aluminum to cast iron water pumps was part of the level 8 engine version in June 1965.  The water pump in your picture looks correct to me.
You might want to provide a picture of the impeller also.
Offline pstone
Re: Water Pump
« Reply #2 on: June 22, 2019, 03:08:00 PM »
Thanks John.  I will put up more pictures in a while.  For some reason the website is not allowing me to at this time.
« Last Edit: June 22, 2019, 03:10:41 PM by pstone »
Offline ChrisV289
Re: Water Pump
« Reply #3 on: June 22, 2019, 03:15:57 PM »
So not to get too far off the topic but if a car had an early June build date, say the first week, the motor I assume would have been assembled sometime in late April to May.  Would these engines of had the cast iron water pump or were they still using the aluminum one?
2009 V6 Mustang Coupe
Re: Water Pump
« Reply #4 on: June 22, 2019, 04:19:30 PM »
- if a car had an early June build date, say the first week, the motor I assume would have been assembled sometime in late April to May.
It's the engine assembly date that is the key, not the car scheduled date. Ford would, in many cases, use up existing inventory then make a change over. This may or may not have been what happened in this case, but was directly related to Change Level 8, which would have been stamped on the the metal engine tag. Mannel gives a range of "May 65 - August 65" (Appendix A pg 8) which is rather wide.
Re: Water Pump
« Reply #5 on: June 22, 2019, 06:35:43 PM »
Just for comparison and a data point do have documentation of a 5E27 assembled engine that was labeled as having the Level 8 improvement  in your VIN range Chris
