Author Topic: 1966 console woodgrain resto kit question...  (Read 1390 times)
Offline 65Val
« on: June 11, 2019, 12:40:44 PM »
Looking at buying the woodgrain console resto kit from Scott Drake, C5ZZ-6504567-AT, and apparently it doesn't come with the little sliver of woodgrain right next to the shift quadrant, as in attached pic. How do you fix this area? Talked to CJ Customer Support, and they have no answer.
Offline NEFaurora
Re: 1966 console woodgrain resto kit question...
« Reply #1 on: June 11, 2019, 05:43:56 PM »
Check out NPD instead.. They'll not only have an answer for you, They'll have the best product available..
:o)
Tony K.
MCA#70001
Offline stangerdude
« Reply #2 on: June 11, 2019, 05:54:27 PM »
Here is my experience (or more confusion?). Talking original automatic bezels only here. Some originals had the thin strip of wood grain. Some did not but had a brown paint applied in that thin area. This was on original non restored 66 consoles only although I did have 2 or 3 later 65's that had the paint as well. Could have been 66 consoles installed though. I also remember long ago seeing a one piece original wood grain insert with the thin strip connecting the two larger pieces. Doubt if this helps but just my experience.   Paul
68 GT Fastback San Jose built
« Reply #3 on: June 11, 2019, 07:14:43 PM »
The original factory console wood grain trim was laid on top of an aluminum "underlayment". Beware of a decal only kit.
True.
Offline outlawincorporated
  • Kangaroo Herder
« Reply #4 on: June 11, 2019, 10:53:47 PM »
i have several NOS wood grain automatic and manual console shift plates in stock and none of the automatic versions have that sliver/section attached they are all painted a very similar colour to the material. I call the colour that best represents it "mission brown"
I have confirmed with mike murray former ANHJ and he agrees with what i have and he has seen this on unrestored automatic console equipped 65 66 mustangs.
with regards to Manual console shift plates my examples do not have that sliver/section painted they are just left as a chrome section.
i can post some photos up a little latter in the day.
regards
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
« Reply #5 on: June 12, 2019, 12:19:28 AM »
+1, the factory originals never had the sliver of wood-grain in that section, always painted brown color.
  • Kangaroo Herder
« Reply #6 on: June 12, 2019, 09:17:47 AM »
here are some images of the NOS original console shift plates to show the area as per original post.
regards.
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
« Reply #7 on: June 12, 2019, 05:31:11 PM »
About 20 years ago an outfit called 'PRO', as I recall, was making aftermarket mustang stuff.  I bought a metal backed console inlay kit from them.  It had the thin woodgrain sliver on the side of the shifter and another 1" x 1" square piece for the lower left section.  Pro has been out of business for quite some time and I have never seen another similar kit offered.  Brian
« Last Edit: June 12, 2019, 05:52:32 PM by Brian Conway »
Offline 5F08KGT
« Reply #8 on: June 12, 2019, 06:31:02 PM »
Contact Tony's classics for a correct aluminum backed woodgrain console kit. I got one from him many years ago and its holding up very well....
« Reply #10 on: June 12, 2019, 08:25:59 PM »
Believe Pro Products was acquired by Scott Drake.
Nevertheless, the side strip is not concours-correct.
Offline ChrisV289
« Reply #11 on: July 03, 2019, 10:45:34 PM »
Was at my friends shop today picking up some watershields and taking a look at some top loaders I am interested in and saw he has what appears to be an original full length console. That sliver looks painted brown
2009 V6 Mustang Coupe
« Reply #12 on: July 04, 2019, 02:19:16 AM »
Found one detailed the other day as I was going through some pictures (imaging that ;)  need to locate and post that one. Any idea of what car your example came from?   Just in cause  we find versions
« Last Edit: July 04, 2019, 02:21:39 AM by J_Speegle »
Offline ChrisV289
« Reply #13 on: July 04, 2019, 11:06:42 AM »
No unfortunately I didn't ask but I can but not sure he will know.  He gathers a lot of parts and cars. If and when you come back to Phoenix, let me know a day in advance and I can send you to his shop during the week to see what I mean. Marcus has been there and I believe got a lot of original front suspension components.  I gave the owner of the car I judged in Houston his information to get a original heater plenum.
