Author Topic: 69 mach 1 - is this a numbers match?  (Read 1057 times)
Offline rindel
« on: June 09, 2019, 05:23:39 PM »
Hi, i attached pic of what is legible from my 351w engine stamp and typed in relevant numbers from my vin above. How do i know if i have original engine?
Offline 70cj428
Re: 69 mach 1 - is this a numbers match?
« Reply #1 on: June 09, 2019, 05:51:39 PM »
Not that it means a lot, But I'd accept that as the original engine.  Most people that restamp parts do too good of a job ....
Offline 69GT350H
« Reply #2 on: June 09, 2019, 07:45:18 PM »
Mine only has the last 6 digits. It's a Dearborn car.
« Reply #3 on: June 09, 2019, 08:29:59 PM »
Good start. Would suggest you check the casting date of the block also if it fits well with the cars real build date (from the Marti report) then I would feel comfortable at claiming that block was original to the car. Can't make the claim for the whole engine without checking the rest of the stamped and casting dates from that item ;)
The picture does need a little bit of documentation - where did you find the numbers stamped on the block? This will help other 69 351 owners with cars built at NJ ;)
« Last Edit: June 09, 2019, 08:32:02 PM by J_Speegle »
Offline rindel
« Reply #4 on: June 10, 2019, 09:47:14 PM »
See a more zoomed out pic of the eng. location was back of engine by flywheel.
Offline rindel
« Reply #5 on: June 10, 2019, 09:48:35 PM »
i have tons of engine pics so i just need to know location of casting dates on block
Offline rindel
« Reply #6 on: June 10, 2019, 09:54:07 PM »
Is this the casting number?
Offline rindel
« Reply #7 on: June 10, 2019, 09:56:12 PM »
and this number as well.  The original owner said it was numbers matching but I could never really prove it until we had to removed the engine to replace the pistons.
« Reply #8 on: June 11, 2019, 12:00:35 AM »
That is the casting number (one under the larger engineering number)
« Reply #9 on: June 11, 2019, 12:59:57 AM »
I believe Jeff may mean casting "date"(a typo) which is the one under the larger engineering number casting. That would be the approximate date that the engine block was cast in the mold.
Offline rindel
« Reply #10 on: June 11, 2019, 09:08:10 PM »
The one that reads C90E-6015-B?
i searched the internet to decode this to "C9OE-B – 1969-1970, 351 Windsor small-block, 2-bolt mains"
« Reply #11 on: June 11, 2019, 09:33:43 PM »
The numbers and letters below are the ones needed the upper one doesnt' help much
Looking at what I can make out do we have a 8H or a 8M  followed by a  13 or19 or something like that?
You would be the best one to tell since you can look at it all from different angles
Given the VIN from NJ plant that would place the car possibly being finished in early Feb 68 making a December 68 cast block (if the letter is an M) a decent fit to other patterns we've seen
« Last Edit: June 11, 2019, 09:36:31 PM by J_Speegle »
Offline rindel
« Reply #12 on: June 11, 2019, 11:24:44 PM »
thanks i will take a closer look and report back
Offline rindel
« Reply #13 on: June 13, 2019, 09:30:23 PM »
My marti report says the following. So would you say its original engine?
scheduled for build: feb 10, 1969
Actually built feb 7th 2 days ahead of schedule.
« Reply #14 on: June 15, 2019, 05:11:11 PM »
The existence of the car's Vin would suggest that the block was original to the car. You would want to check all the attaching parts to confirm that the complete assembled engine was all original or at least in the date range before claiming IMHO that the engine was original or "matching numbers" if that was the term you wanted to use.
Ever get a chance to look at the block casting again and that will help with dating the rest of the parts and the assembly date
