Author Topic: HiPo Axle Diameter  (Read 481 times)
Offline Snydly289
HiPo Axle Diameter
« on: June 04, 2019, 11:56:14 PM »
Hello all!
Were the axle shafts on a 65/66 K Code HiPo 9" rear ends a different diameter than the standard 8" axle shafts?
I know the lengths of the HiPo 9" axle shafts were the same as the standard 8" axle shafts, and both were obviously 28 spline. I measured the diameter of my genuine 65 HiPo axles shafts, they came out to be 1.223 ish inches. Is this the general diameter of all 9" axle shafts?
I do not have direct access to the standard 8" axle shafts at this time to measure and compare.
Riley
65 K Code Fastback -5F09K325XXX, Oct. '64, Vintage Burg, Rally Pac, Arvinode Exh, lots '64 items
66 A Code GT Coupe -4 speed, bench Seat, P/S, A/C, Rally Pac, handling package, 8 track
66 A Code Fastback -Built 302, 66 S2MS Intake, WC T-5, 4-wheel Wilwoods, locking 9"
66 T Coupe
65 T Code Fastback
Offline usapony
Re: HiPo Axle Diameter
« Reply #1 on: June 07, 2019, 06:45:05 AM »
The axles in a K code 9" are the same as the axles in a 8"
