Author Topic: Tap size for UCA  (Read 1307 times)
Tap size for UCA
« on: June 02, 2019, 08:03:36 PM »
The threaded portions of my [67] upper control arms need some help.
Can someone cross check me that the tap would be a 1.175"-16 ?
[edit -- zero out the digital caliper, dummy]
« Last Edit: June 05, 2019, 02:44:48 PM by Bossbill »
Offline 69bossnut
    • DSD Restorations LLC
Re: Tap size for UCA
« Reply #1 on: June 13, 2019, 07:07:06 PM »
Not sure of the size. But originally the shaft end caps would cut their own threads. You just need to swege the hole to make a little smaller so it will recut the threads.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
« Reply #2 on: June 13, 2019, 07:44:42 PM »
Yeah, you're right.
The cap is really, really hard. A file or re-threader won't touch it. And I think someone just made up a thread size because you cannot find a tap anywhere close.
The UCA is just mild steel and the cap should just cut right into it.
I think I'll give that a try.
Thanks for the suggestion!
