Author Topic: Fan ID  (Read 1409 times)
Offline Brian in PA
Fan ID
« on: May 26, 2019, 04:13:32 PM »
Good afternoon.  Mods please move this if I posted it in the wrong place.  I have a fan that I’m trying to identify. It was on a 67 390 no ac car. I can’t find any that look like this, nor can I find any part number or fomoco stamps. It looks like a ford fan but not the correct for my application.  Thanks
Brian
Sorry it’s 17 1/2 diameter. Thanks
« Last Edit: May 26, 2019, 04:17:16 PM by Brian in PA »
Offline preaction
Re: Fan ID
« Reply #1 on: May 27, 2019, 12:31:42 PM »
Brian, you need a C6OE-E fan this part is 18 1/4" wide with the engineering number on the back and  Ford in an oval on the front.
Offline Brian in PA
Re: Fan ID
« Reply #2 on: May 27, 2019, 06:19:37 PM »
Thanks. I’ll start looking for one of those then. Any idea what this is off of ?  Thanks
Offline 67350#1242
Re: Fan ID
« Reply #3 on: May 27, 2019, 10:23:40 PM »
I believe the correct 67 390 clutch fan part number is C6OE-F
https://secure.cougarpartscatalog.com/c6oe-8600-f.html
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline preaction
Re: Fan ID
« Reply #4 on: May 28, 2019, 01:13:07 PM »
C6OE-F  +1
Offline Brian in PA
Re: Fan ID
« Reply #5 on: May 28, 2019, 10:15:32 PM »
Thanks guys!  So what is this fan from?
Re: Fan ID
« Reply #6 on: May 29, 2019, 12:06:11 AM »
Without some identification (engineering number) there is little way to tell for sure. You can make a guess of a possibility by trying to match the dia, what details you do have and center style to the information provided in a copy of the MPC.
Bunch of them to compare to on those pages under the base number 8600
« Last Edit: May 29, 2019, 12:09:57 AM by J_Speegle »
Re: Fan ID
« Reply #7 on: May 29, 2019, 09:56:51 AM »
Judging by the lack of markings I am going to guess it is some sort of aftermarket fan that uses a fan clutch. Maybe Hayden? There used to be many companies that made fans and fan clutches that you could buy at the auto part stores.
Offline Brian in PA
Re: Fan ID
« Reply #8 on: May 29, 2019, 06:17:37 PM »
Ok thanks. I never thought about after market.
Re: Fan ID
« Reply #9 on: May 30, 2019, 05:48:12 PM »
The SC stamp shown in your second picture, is something we see on Ford fans often but sub contractors could also make aftermarket, service replacements and factory items at the same of different time periods.
