Author Topic: What is this bracket for?  (Read 883 times)
Offline must69
« on: May 21, 2019, 03:24:46 PM »
This bracket is from my 64.5.  I believe it goes on one of the switch shafts on the dash, but unsure which one?
Re: What is this bracket for?
« Reply #1 on: May 21, 2019, 03:26:21 PM »
It is normally spot welded to the headlamp switch.
Offline ChrisV289
« Reply #2 on: May 21, 2019, 03:57:53 PM »
+1
2009 V6 Mustang Coupe
Offline stangerdude
« Reply #3 on: May 24, 2019, 05:02:59 PM »
That bracket / spacer is correct for 64 1/2 (units built before 8/17/1964) and was NOT spot welded to the headlight switch assembly. It was used as a spacer between the switch and backside of the dash. They were a separate piece in 64 1/2 for the service part number C5ZZ-11654-A. The later C5ZZ-11654-B had the bracket welded to the switch assembly. The two switches are not interchangeable by the way, since Ford decided to make the spade connector configuration a bit different.  Just my experience and of course not set in stone!   Paul
68 GT Fastback San Jose built
« Reply #4 on: May 25, 2019, 12:04:08 PM »
You are so right! I owned a early '65 D code Mustang and never knew the headlight switch was specific to Generator equipped early cars! There are a couple of them on eBay right now where I got this picture:
Offline ChrisV289
« Reply #5 on: May 25, 2019, 05:55:07 PM »
There is also a headlight switch used between August 7,1964 and November of 1964.  Not sure what the difference is between that one and the later 65.
Offline NEFaurora
« Reply #6 on: May 27, 2019, 02:18:38 AM »
Some Later "Over the counter" Motorcraft Headlight switches and also some Aftermarket Headlight switches had the bracket as an "add-on" inside the box seperately instead of it being welded on the headlight switch as original so that the headlight switch could cover more Ford and Mercury vehicles other than the Mustang.
:o)
Tony K.
MCA#70001
Offline must69
« Reply #7 on: May 29, 2019, 01:48:03 PM »
Thank you all for the great information!  Another item specific to the 64.5.
Phil
