Author Topic: 68 J-Code Automatic Drive Shaft Markings  (Read 9206 times)
Offline stillboardin
« on: November 14, 2010, 01:16:12 PM »
I have a San Jose J-code January build C4 that is original.  I am starting to clean up the drive shaft and am loking for some help on the colors codes on the drive shaft.
From what I have read and seen the yoke casting is red oxide or orange.  Is there a specific color for this?
The stripes on the drive line appear to be (from back to front)
1.  2 white strips approx 6 to 9 inches from the back end of the tube.
2.  3 colored stripes about 24 inches in look like green white yellow
3.  one thin stripe toward the front looks to be white
4.  looks to be a crayon x between the colored strips and the first 2 white stripes
Photos below
My plan is to clean up the drive shaft and restore it to like new.  So my question is what type of paint and colors do I use for the stripes?
Should I put a clear coat on the shaft to protect it from rust?  or a cast paint? or leave it?
By the way this is not a concours resto but I do want it to look really good.
« Last Edit: September 07, 2022, 02:36:51 PM by J_Speegle »
68 Coupe
8R01J131182
Owned since 1981
Currently in various stages of restoration
Re: 68 J-Code Drive Shaft Markings
« Reply #1 on: November 14, 2010, 10:45:35 PM »
I have a San Jose J-code January build C4 that is original.  I am starting to clean up the drive shaft and am looking for some help on the colors codes on the drive shaft.
Yes some yokes were painted orange (to identify them for the driveline assembler) but not all of them. Question - did your car come with the 9" or 8" rearend?
Photos below[/quote]
The X has been seen on some but not all drivelines in 68 at San Jose
Question - When was this car built?  Reason for the question is that the marks you found do not match any J code buildsheet written paint marks for a driveline. Any chance the driveline has been replaced?
For paint I typically use just about anything (hobby, Rustoleum, spray can paint) that matches the color and tint. I do a fair amount of marks on cars so I have a collection of 40 or so different samples I mix to get just the right color
As for protection I would use a good oil such as Bioshield,  Crossion X or similar thin film protective oil product
« Reply #2 on: November 15, 2010, 12:30:48 AM »
Quote
The car has an 8 inch rear 3.00 gears
Quote
The build date was Jan 23rd, 1968.
We have had the car since 1981 and when my wife bought it is was pretty original.  I guess it could have been replaced before 1981.
Is there anything they do match?  What would a typical j-code drive be marked like?
68 Coupe
8R01J131182
Owned since 1981
Offline DTruitt
« Reply #3 on: November 15, 2010, 10:45:52 PM »
Jeff, good catch/ question about the rear end being a 8" vs 9"!  Is the drive shaft a one piece or two piece drive shaft?
My cousin recently cleaned and detailed his San Jose J-code, A/T, drive shaft.  It is a GT, has a 9" rear and a two piece driveshaft; the color codes were different on his compared to yours.
It looks like you have a great reference to use.  The engine and trans should have a partial VIN stamped into them to verify if they have been changed and the rear end tag should have a date code on the rear end tag.  These things along with casting dates will verify if the drive train was ever changed.
Danny
1968 Raven Black, S- Code, 4 spd., GT Fastback, San Jose, March 1968
1968 Candy Apple Red, J- Code, C-4, GT Convertable, San Jose, April 1968 (SOLD)
1968 Raven Black, R- Code, 4 spd., GT Coupe, Dearborn, April 1968
MCA Gold Card Judge
« Reply #4 on: November 15, 2010, 11:07:40 PM »
Engine and trans are both original and have correct VIN's.  I will check the rear end in two weeks as the car is 200 miles away at my Father in laws.
The drive shaft is a two piece.
Also, I am assuming the rear end is a 8" just because of the gears (3.00:1)  I would think a 9" would have been 3.25:1 or higher.
68 Coupe
8R01J131182
Owned since 1981
« Reply #5 on: November 15, 2010, 11:48:07 PM »
Don't assume that  but we would expect a GT to have the 9" and the non GT to have an 8"
As a response to your earlier question  - buildhsheets indicate that the small block automatic with the 8" was marked Dark green, Lavender and White at San Jose about when your car was built. I would not expect the end yokes to have orange on them
« Reply #6 on: November 16, 2010, 01:02:06 AM »
Here is a picture of the yoke and the part number.  Does this tell you anything?
68 Coupe
8R01J131182
Owned since 1981
Offline T Lea
« Reply #7 on: November 16, 2010, 08:30:33 AM »
I would say both statements are true about GT and 3.25 and lower are 9". That driveshaft is from a 8", here is a C4 9" shaft,
I should have build sheets I can check for yours, I'm crazy busy right know so if I forget remind me in a day or two
Offline gtamustang
  • CPM
« Reply #8 on: November 16, 2010, 04:31:53 PM »
Your yoke is consistent in part number and color with a 68 289/auto coupe that I am restoring on the other side of the states...built in May 68 at Metuchen. Also, the drive shaft is a tube in a tube configuration with pink/green/white center stripes and 2 tail end white stripes. I will have to take pictures and post them when I pull it out of the evapo-rust.
Regards,
Pete Morgan
« Reply #9 on: November 16, 2010, 11:48:35 PM »
Tim - have seen cars and buildsheets with 3.25's that were 8" in 68 - just sharing
Have plenty of J code Shelby buildsheets if that is what you are referring to- just wanted to keep from mixing up the two until stillboardin the  checks his car to see which (for sure) rearend he has ;)
Offline T Lea
« Reply #10 on: November 17, 2010, 09:01:41 AM »
Never knew that. I thought 3.25 and lower were all 9
Quote
Actually I was referring to others. I probably have 20-30 T and C code NJ build sheets
« Reply #11 on: November 25, 2010, 04:30:43 PM »
Looks like a 8 inch.
68 Coupe
8R01J131182
Owned since 1981
« Reply #12 on: November 26, 2010, 01:55:53 AM »
Here is the tag from the carrier.
The date code is consistent with the build date.
68 Coupe
8R01J131182
Owned since 1981
« Reply #13 on: November 27, 2010, 12:17:51 AM »
Yes that is an 8" with 300 open gears
On the buildsheets those are coming up - (for the driveline)
Medium Blue, Lavender, White
Offline Sunlitgold68
« Reply #14 on: December 08, 2010, 08:58:52 AM »
This is the driveshaft Pete Morgan was referring to. Restored by Pete... this is my original 1968 C code driveshaft.
« Last Edit: December 08, 2010, 09:00:40 AM by Sunlitgold68 »
8T01C204XXX
Built May 14th, 1968
