Author Topic: Mach 1 Side Scoop Questions  (Read 555 times)
Offline jgkurz
« on: May 02, 2019, 03:30:51 PM »
Hi all,
I am in the middle of a re-paint and have a few questions regarding my 69 Mach 1 Q-code assembled in Dearborn.
1) Do the scoops have some kind of seal or backing or are they simply fastened to the quarter panel?
2) What color should the side scoop block off inserts be? Color of the car or black satin?
Thank you,
Offline 7Lscjracer
Re: Mach 1 Side Scoop Questions
« Reply #1 on: May 03, 2019, 01:39:14 AM »
They have strip caulk on the back, because they're painted separately so water would get in otherwise.
Probably the same grey stuff used under the front fenders for example.
Considering the inner fenders are painted black, why black caulk wasn't used to blend in instead of grey sticking out like a sore thumb is a mystery to me.
Anyway, it is what it is.
The scoop block offs are black, not body color.
Some people just think they are because of cheap, lazy repaints with the scoops not removed from the car.
Bought May '81, sold Sept '20
Offline jgkurz
« Reply #2 on: May 03, 2019, 10:00:54 AM »
Just the info I needed. Thank you.
