Author Topic: Sway Bar Bushings 68 GT350  (Read 1897 times)
Offline John Quinn
« on: November 13, 2010, 06:34:03 PM »
The sway bar bushings I found on my GT350 are somewhat different to a set I just received.  The new bushings don't "fill up" the sway bar bracket as the ones found on the car do. There are a couple of other versions of bushings currently available but none seem to be formed or fit like the old ones.  What would have original bushings looked like?
« Last Edit: November 14, 2010, 12:11:34 AM by John Quinn »
Re: Sway Bar Bushings 68 GT350
« Reply #1 on: November 14, 2010, 01:28:43 PM »
The last picture. The Ford service replacement is a fit all type and dosn't fit like the assembly line . It fits very well on a smaller diameter bar though. R-A motorsports sells the correct 15/16 bushing. 816 246 9094. Tell them I told you to call. i hope this helps. Bob
Offline John Quinn
« Reply #2 on: November 22, 2010, 01:06:59 AM »
Thanks Bob  :)
Offline 68 S Code
« Reply #3 on: November 23, 2010, 12:11:30 AM »
This question relates to this topic but my question is related to the bracket holding the rubber bushing. Is that bracket used only for the 15/16" bar or also for the 7/8" sway bar with a different rubber insert?
