Author Topic: 69 Mach 1 stripe need some help  (Read 1179 times)
Offline DEWilson
    • Maine Mustang Back from the Dead Restoration Shop
« on: April 29, 2019, 10:42:56 AM »
69 mach 1 side stripes   has anyone  take measurement of oem one  what is the correct size for the center pinstripe is it 1/4" or is it the 5/16"? then on the outside pinstripe is the bottom thicker then the top ?, or are they same thickness all the way around? what is the outer pinstripe width size or sizes ?   then what is the width of the center stripe part ? what the gap size between center and outer stripe ?  then the taper of the stripe overall width at the rear maker light ?   then at the front overall width just passed the 1 ?
why i am asking is i have a old oem replacement set that was notable to use the gold center stripe is breaking up,, so just got a aftermarket set that say they are concourse correct but it don't have the same measurements as the oem set i have,,  I am being told  oem service one where made wrong is this correct?  i am seeing there is a 3/16  difference in front overall width between the oem ford replacement one and aftermarket one in all there is seval size difference so any help on some measurement would be greatly helped
And last the center pinstripe part was that printed on or another decal apped on top of the reflective decal
« Last Edit: September 29, 2019, 01:21:01 PM by DEWilson »
Offline DEWilson
Re: 69 Mach 1 stripe need some help stripe measurements
« Reply #1 on: April 30, 2019, 08:24:03 PM »
  here is a pic of the two stripes
Offline DEWilson
« Reply #2 on: May 03, 2019, 04:26:24 PM »
  what is the correct size for these stripe  top one 2 5/8 " or the bottom one at 2 7/16
« Reply #3 on: May 04, 2019, 10:20:22 PM »
On my Car; 2-7/16" measured at the #1.  The width grows as they progress to the rear of the car.  Aft of the marker light 3-1/8". Brian
Offline DEWilson
« Reply #4 on: May 05, 2019, 02:42:55 PM »
thank you  what is your size of the center pin stripe is it 1/4 inch
 what i am being told that NPD stripe kit got messed up in it setup and is 8% oversized in the width,,  so what they have in stock are wrong   does anyone know where i can get good replacement stripe
« Reply #5 on: May 05, 2019, 03:12:03 PM »
5/16"
Offline DEWilson
« Reply #6 on: May 06, 2019, 12:13:33 AM »
  ok thank you     anyone  wont chime in on the width of there mach 1 center stripe size  are they 1/4"   or    5/16 "
Offline DEWilson
« Reply #7 on: May 09, 2019, 03:40:19 PM »
  ok try to still get what is out there on 69 mach 1 stripe overall width ((outside of pinstripe too outside pinstripe)) at the front of the stripe measured just past the 1 of the mach 1        got one at 2 7/16
Next need is the center pin stripe width    got 1 @ 1/4"inch and 1 @ 5/16 inch
Offline DEWilson
« Reply #8 on: September 29, 2019, 01:19:49 PM »
  Hi All  like to know where i can get a new 69 mach 1 stripe kit from had gotten the one made by decal magic that was lic by ford but they where not to correct oem measurements" and they agreed that what they was making was wrong, they would fix them but 7 month later and two promised ship date passed by i am with out any thing and now no one returning my phone call i am look for help to find where i can get a good mach 1 stripe kit
« Last Edit: September 29, 2019, 01:22:20 PM by DEWilson »
