Also posted this over at the 428CJ site ........
Does anyone here have a 70 428 AC car with a known original Alternator ? I'm beginning to suspect that all D0ZF-C Alternators were built with a dual sheave pulley and if the car had AC, the second sheave wasn't used. When I got my R code car way back, the original alternator had a dual sheave pulley on it and I just assumed it was off a non AC car. since then I've seen two other original 70 428 AC cars that both also had a dual sheave AC pulley (with one unused sheave). I just bought an ugly but pretty original Q code car (with AC) and it also had it's original D0ZF-C alternator with a dual sheave pulley. I can't imagine why anyone would have just switched the alternator pulley on this car as it still has it's original water pump, alt, rad, carb, distributor, fuel pump, ect ....
Another reason I think that all 428 cars in 70 got the dual sheave AC pulley is that all the 428 applications used the same part number alternator, and I'm sure the alternator was supplied with the pulley. ( If Ford wanted to use a single sheave pulley, they could have just specified the Boss 302 alternator (D0ZF-A) that's identical to the "C" alternator except it has a single sheave pulley.) 1969 428CJ cars have 2 separate part number alternators, C9ZF-B and C9ZF-C, the only difference being the pulley.....
Thoughts
