Author Topic: Bellhousing rivets  (Read 1110 times)
Offline preaction
Bellhousing rivets
« on: April 16, 2019, 09:57:36 PM »
Has anyone come across a source for the rivets used for the pivot point that mounts a clutch fork  I have seen them before serviced by ford but that has been some time ago.
« Last Edit: May 17, 2019, 12:22:51 PM by preaction »
Offline preaction
Re: Bellhousing rivits
« Reply #1 on: May 16, 2019, 03:01:11 PM »
I wanted to give this one more try. ;)
Offline 67350#1242
« Last Edit: May 16, 2019, 04:33:21 PM by 67350#1242 »
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #3 on: May 16, 2019, 05:23:25 PM »
I assume that these rivets are pressed in, but how? Can this be done with a 20 press?
(The search engine is "letter selective". The correct spelling is "rivet". The other spelling should be tried as well. Thanks a lot for your attention.)
Offline preaction
« Reply #4 on: May 16, 2019, 10:18:17 PM »
Jim I think they need to be heated and pressed they are pretty heavy at IIRC 5/16" its been some time since I did a set.
« Reply #5 on: May 17, 2019, 12:10:06 AM »
It was more of a "rhetorical" installation question. For some reason, all three of my C4 equipped Mustangs don't have one.  ;)
Re: Bellhousing rivets
« Reply #6 on: May 17, 2019, 02:30:00 PM »
Air chisels are no substitute for a real rivet gun Like the Ingersoll-Rand  AVC12 or 13. People are having issues with rivets due to using the wrong tool. Just what others in the tool business say.
Why use a rivet at all? Just use the correct size "Flat Head Countersunk Socket Cap Screw" and fill in the hex.
