The stamp is only required on thoroughbred and unrestored categories
Does anyone make the Autolite yellow top ignition coil with the stamp rather than the decal? MCA judges will knock points off if your coil has a decal.ThanksBeatlemike
For those that are interested you might consider some things. Do you want to buy a repro coil that has been stamped? Are you sending a coil that you have that is repro or original to be stamped? Is the coil you are sending already restored or do you need it restored? Are you wanting to buy a original used coil that has been cosmetically restored and stamped? All of these things will have a effect on a price and in many case what a particular seller may even be prepared to do. FYI as has been mentioned although dated stamps are nice once oriented in the coil bracket the date is most typically obscured by the bracket regardless of where it is mounted on the engine.typically the top portion or bottom portion is all that can be seen. The stamps were seldom perfect and frequently smudged in some way or the other . That is just how many were from the MFG.
Thank you Ruppstang. Yes, it appears Jack at Dead Nuts On will sell you an original Autolite or a repro coil with the stamp. He even will orient the placement of the stamp on the coil so it's visible. Just let him know which engine you have. As I mentioned in my original post, MCA rules (for 67-68 concours) require the stamp. If you have the decal, there's a 1 or 2 point deduction. I found out the hard way. Beatlemike 68 Dearborn plant
and better yet is it any good? I barely got a year out of my reproduction. I believe it had the sticker also.
