Author Topic: 65 Fuel pump  (Read 1787 times)
65 Fuel pump
« on: April 13, 2019, 12:27:41 PM »
What is the assembly line type fuel pump for a mid-May 65 San Jose A code, 4 speed car ? This pump, origins unknown, has been on the car for ages and I use an external, in line, filter for it.  Should I have the canister type fuel pump ?  Carb is C5ZF-C  C5EA.  Thanks Brian
Re: 65 Fuel pump
« Reply #1 on: April 13, 2019, 01:55:34 PM »
Mid may 65 V8 fuelpump would be the Canister type,button top,typically CAR bure TER marked unit,and with a 5/16 fuel inlet. The one in your picture is a generic auto parts store replacement.
Re: 65 Fuel pump
« Reply #2 on: April 13, 2019, 02:38:30 PM »
https://www.ebay.com/itm/1965-Ford-Mustang-Fastback-Cpe-GT-Convertible-ORIG-260-289-BUTTON-TOP-FUEL-PUMP/163643680181
Thanks Bob.  So exactly like this ebay offering ?  A closer date code ?  Brian
« Last Edit: April 13, 2019, 07:48:53 PM by Brian Conway »
Re: 65 Fuel pump
« Reply #3 on: April 13, 2019, 03:14:14 PM »
http://www.ebay.com/itm/1965-Ford-Mustang-Fastback-Cpe-GT-Convertible-ORIG-260-289-BUTTON-TOP-FUEL-PUMP-/163643680181?hash=item2619ec65b5
The fuelpump is appropriate . The date code is not ideal for a mid 65 built car.
Re: 65 Fuel pump
« Reply #4 on: April 13, 2019, 03:52:58 PM »
OK thanks again Bob.  I think this is the 3rd block in this car.  So I need to remember that date correct original parts are not a real priority.  When possible I like to recover the assembly line parts.  This car has always been a driver so many of the accessory items were auto parts store replacements.  Brian
Re: 65 Fuel pump
« Reply #5 on: April 13, 2019, 04:03:48 PM »
For later when the ebay link is long gone ;)
NOTE: Bob nudged me and reminded me that I had posted an earlier version so its corrected now  :)
« Last Edit: April 13, 2019, 07:19:04 PM by J_Speegle »
Re: 65 Fuel pump
« Reply #6 on: April 13, 2019, 05:59:46 PM »
I think the right looking pump is the most important aspect on all but a Thoroughbred class show car. The date code is secondary IMO.
Re: 65 Fuel pump
« Reply #7 on: April 13, 2019, 07:02:30 PM »
+1 to that theory.
Offline outlawincorporated
  • Kangaroo Herder
Re: 65 Fuel pump
« Reply #8 on: April 13, 2019, 09:51:13 PM »
and dates are only relevant to throughbred and unrestored class if im not mistaken in MCA classes
too many people get hung up on correct dates on parts now a days. I understand wanting to be correct and all but there are many other things I will look at on a mustang before I even consider dates/months/years
regards.
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
Re: 65 Fuel pump
« Reply #9 on: April 14, 2019, 01:21:27 PM »
regards.
PHILL BERESFORD
MELBOURNE.
AUSTRALIA.
+++++++++1
Offline ChrisV289
Re: 65 Fuel pump
« Reply #10 on: April 14, 2019, 02:03:44 PM »
I assume this is a replacement carter? Can’t read the date code on it. Plan on having Fred rebuild it for my blue fastback.
2009 V6 Mustang Coupe
Re: 65 Fuel pump
« Reply #11 on: April 14, 2019, 04:15:17 PM »
I would hold out and try to find a CAR bure TER marked one if I were you. They are out there just as the ebay auction demonstrates.   I would not waste money on a generic Carter version, but that is just me.
Offline Hipo giddyup
Re: 65 Fuel pump
« Reply #12 on: April 15, 2019, 10:43:51 AM »
I will be sending a few pumps to Fred as well. He will want to put the right fuel pump on your car. I too have a late 67'-68' CARTER button top pump with a July 67' date but it is not correct for my 11/66 built 67. He thinks I should search out the correct CARBureTOR stamped pump even if the date is off. So, I am again on the hunt and will likely sell out my late 67'-68 small block core.
Also, if your first pic is your engine, it has a later timing cover, one of a 302. Not sure if it matters to you or not but it is easily identified, just like the fuel pump.
