Author Topic: Shelby Intake Elbow Removal  (Read 1228 times)
« on: April 10, 2019, 05:40:47 PM »
Over the years I've removed hundreds of stuck nuts, bolts. and other items.
But this one scares me a bit since the item is original and somewhat costly.
My Shelby aluminum intake has a rather stuck water elbow I want to replace:
Assume I first slather the top and bottom of the casting with Liquid Wrench or Kroil. I can get to the bottom through the thermostat housing hole.
I could also heat the surrounding area, only heating the unseen area underneath.
Any other tips?
Re: Shelby Intake Elbow Removal
« Reply #1 on: April 10, 2019, 05:44:09 PM »
An engine guy I respect uses heat and candle wax.
« Reply #2 on: April 18, 2019, 09:21:19 PM »
Well, I'll be dipped -- in wax!
I tried this on some very stuck upper control arms pivots using a plumber's propane torch and paraffin wax and it worked.
I then got brave and tried it on my intake.
As Edd says, "Results!"
« Reply #3 on: April 18, 2019, 09:29:13 PM »
Holy wax, batman.  The guy that told me about this laughs at all of the "high falutin" chemical concoctions when wax does the trick.
« Reply #4 on: April 18, 2019, 09:38:14 PM »
I did, however, catch a rag on fire that was protecting the UCA from the vice jaws.
I then manged to catch another rag, some kraft paper and the table on fire while doing the intake.
Fire and wax -- who knew?
« Reply #5 on: April 19, 2019, 09:04:40 AM »
TRANSLATION: I burned the garage with the car down but I saved the costly INTAKE. WIN~ ;D
Offline Murf
« Reply #6 on: April 19, 2019, 11:45:30 PM »
How about a step by step tutorial on using the "wax system of removing steel from alloy" ?..
John Murphy
« Reply #7 on: April 20, 2019, 01:08:01 PM »
Using duckduckgo.com and entering "rusty bolt removal with wax", it took all of 10 seconds to find many websites, youtube included, describing this technique.
« Reply #8 on: April 20, 2019, 03:02:20 PM »
For fine, small parts that require great accuracy I use a small Benzomatic.
For larger stuff I use my trusty plumbing torch head from the same manufacturer. So much easier to move around a small torch head on a flexible hose than mess with the all in one versions. Plus, those torch heads on the can don't always turn off, do they?
That's what I used in this example. And it absolutely turns off.
If you really need heat, an oxy/acy torch is another remedy. Would not recommend on aluminum.
