Cut and pasted from a thread for the 68 289 engine painting we have Jeff's reply quoted here. Were there many other differences for 1967 THERMACTOR 289's?
My understanding is the Thermactor cast iron bracket is supposed to be mounted before paint. I assume it gets fully painted, is that much true? Also, the Thermactor Check Valves and tubes in place for paint and with Closed Emissions option, the breather cap filler pipe is in place before paint.
Any other differences? Do the wiring harness ribber-dipped J clips also get painted and if so, the RH valve cover center upper bolt ( per the Assembly Manual) has a J-clip for a vacuum hose on AC-Equipped cars and since the PVS is stated to be installed before paint, does this J clip also get paint?
Some of these details can be viewed in other threads including the 1968 San Jose pictures of the engine drop of a small block as well in some of the unrestored picture threads for your year. Another thread that might be helpful is "17,000,000 Engine at Cleveland Engine Plant" I suggest that you look them over for additional details
For a 68 small block V8 non Thermactor engine.
Only focusing on the items you can see from the exterior of an assembled engine you basically have the
- Engine block with drain plugs and freeze plugs installed
- Cylinder heads with attaching hardware
- Exhaust manifolds with attaching hardware
- Valve covers with only two retaining bolts in place. Upper corners only.
- Two rubber covered clips attached at the two drivers side valve cover bolts mentioned above.
- Passenger side spark plug wire relocator bracket and attaching hardware
- Oil pan with attaching hardware and drain plug
- Intake manifold with carb spacer (carb may have been in place and shielded) with attaching hardware. Pain on spacer often fades away towards the upper surface
- Thermostat housing with attaching hardware
- PVS - masked off with removable mask
- Intake heater hose connection fitting
- Bypass coolant hose and with attaching hardware/clamps
- Timing cover with attaching hardware
- Water pump with attaching hardware
- Timing pointer with attaching hardware
- Rear engine plate
- Fly wheel with attaching hardware. Rear face of the engine and this plate, would not normally be painted
- Dip stick tube and dip stick
- Water temp sender may have been installed with a slip over mask/shield
Some of the surfaces were protected from becoming painted
- Slip over masked installed over the thermostat housing and water pump water necks.
- Unused water pump and intake heater hose connection points.
- Fuel pump attachment surface was also protected from paint.
- The mounting surface (for the pulley) of the water pump
- The oil filter (though painted engine color) has been debated over the year and I believe we're not certain if it was in place during painting (receiving some paint over the other coat of paint close to the mounting surface) or not.
From there the engine assembly was painted leaving the area/surface where the starter would mount up to unpainted either by masking off the area
Think I got it all. If not sure one of the helpful members will lend a hand
