Author Topic: Valve Cover PCV Baffle Filter?  (Read 474 times)
Offline s2ms
    • 6S1757 Info
« on: April 03, 2019, 12:50:35 PM »
Crazy question but I'll ask anyway...
Is there any chance OE valve covers originally had a mesh material inside the PCV baffle like the attached photo? Or is this simply someone's attempt to reduce oil mist from being sucked into the intake?
I realize it's highly doubtful, I only ask because I have seen this more than once on original used SB covers. In fact, I've seen it enough that it made me wonder...
Dave
Offline markb0729
  • South Jersey
Re: Valve Cover PCV Baffle Filter?
« Reply #1 on: April 03, 2019, 05:17:21 PM »
That “mesh” is not factory installed.  It’s an attempt to keep oil from getting sucked into the PCV valve and into the intake.  I suspect those valve covers are not original, something was changed in the valve train or somebody thought it should be there.
« Last Edit: April 03, 2019, 05:21:20 PM by markb0729 »
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
