Author Topic: 69 Mach 1 Trunk Pad  (Read 860 times)
Offline orlandod
69 Mach 1 Trunk Pad
« on: April 02, 2019, 12:12:31 PM »
I have a 351 V4 San Jose car with a date of March 18, 1969. I got the car with no spare, jack and trunk pad. I am trying to source a quality trunk pad and felt spare tire liner plus jack and hold down. I realize I have a laundry list on this thread but would rather purchase the correct items the first time so any leads and or suggestions would be appreciated.
1969 Mach 1
San Jose
351W-4V
Built 03/24/69
3.00/FMX
Re: 69 Mach 1 Trunk Pad
« Reply #1 on: April 02, 2019, 05:49:02 PM »
Lets see how much I can cover in this first attempt
Many of these items are covered and discussed in individual threads so try the search
You'll possibly need
1- Trunk board to cover the gap between trunk floor and the quarter panel. This will be a stiff press paper product available through most Mustang parts sellers. Not sure if there is allot of differences out there. Some vendors in the past use to stick a label on the material and removing it could damage the finish so this might be a consideration for some
2- Spare tire board. Made of Masonite . Jack at DeadNutsOn sells a reproduction for 69 with gray sealer or you might be able to have him leave that off so you can use yellow like San Jose used IMHO
3- Underlayment . Either for just over your gas tank or stretched across the trunk floor if you have a Grande or Mach I. There is an article in the Library with how I made my own.
4- Trunk mat - Not sure how many reproducers there are or if there is just one all of the shops are selling. A San Jose one would have the same speakled top and burtex backing as the other two plants
5- Jack. Available only as a used item. to determine what you need (correct for your plant and year) check out the Jack article in the sites Library
6- Jack hold down - This Scott Fuller Reproduction link should help http://www.scottfullerreproductions.com/catalog/item/4595229/6752241.htm
7- Lug/jack wrench. Not available as a reproduction that I'm aware of
8- Felt spare tire liner or what ever the official name is. Haven't purchased one recently. In the past found some to not be stiff enough. Hopefully others that have had more recent experience with any of these items will offer their observations and help you out further. At least this is a start
« Last Edit: April 02, 2019, 06:17:30 PM by J_Speegle »
