Author Topic: 1969 SCJet Driveshaft & Rear spring Markings  (Read 1452 times)
Offline dmg67
« on: April 02, 2019, 08:22:35 AM »
Hi All, Could someone tell me the color markings and dimensions on a driveshaft on a 1969 Mustang 428 Super Cobra Jet, 4 Speed, Metuchen built on January 1969? Thanks in advance.
« Last Edit: April 04, 2019, 05:32:56 AM by J_Speegle »
Offline sah62
Re: 1969 SCJet Driveshaft Markings
« Reply #1 on: April 02, 2019, 08:26:35 AM »
You might find this helpful: https://www.428cobrajet.org/id-driveshaft
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline dmg67
« Reply #2 on: April 02, 2019, 04:32:23 PM »
Thanks Scott, appreciated.
« Reply #3 on: April 02, 2019, 04:59:37 PM »
For the identification markings. Examples from just before and just after your cars time period. Mid Dec and first of Feb
Offline dmg67
« Reply #4 on: April 03, 2019, 05:05:49 AM »
Thanks Jeff, appreciate your assistance.
Offline dmg67
« Reply #5 on: April 03, 2019, 05:11:07 AM »
Scott or Jeff, same car 1969 Super Cobra Jet, 4 speed, January built, could you tell me the color markings for the rear leaf springs, please? thank you.
« Reply #6 on: April 03, 2019, 01:01:25 PM »
What body style?
Guessing PS without AC with C9AZ-5556-G rear spring markings?
If so this read might help
« Last Edit: April 03, 2019, 01:03:47 PM by J_Speegle »
Offline dmg67
« Reply #7 on: April 04, 2019, 04:57:48 AM »
Sportsroof, No A/C.   With P/S and Smog. Thanks Jeff...
Re: 1969 SCJet Driveshaft & Rear spring Markings
« Reply #8 on: April 04, 2019, 05:32:48 AM »
As mentioned I would think you likely have the C9ZA-G rear springs check for the markings.
The markings on the buildsheets I have match that spring in my observations and are marked with 1 Gold and 1 Violet stripe at the rear end of the spring as mounted on the long leaf as shown in an example of a redone spring in the following thread
http://www.concoursmustang.com/forum/index.php?topic=226.msg1897#msg1897
IF you haven't found it already there is an article in the library about general paints showing examples and typical paitn colors used.
Offline dmg67
« Reply #9 on: April 04, 2019, 08:16:25 AM »
Yes, they're C9ZA-G Springs. Your advice and information has helped me out, thanks Jeff.
