Author Topic: 68 FE bell housing  (Read 1467 times)
68 FE bell housing
« on: March 23, 2019, 09:47:19 AM »
I bought a 68 S code basket case project a few months ago. It is a Four speed manual transmission and the bell housing that came with it is a C5TA 7505 B.
  It appears it should have a C6 OA 6394 D.
 My question is will the C5 TA 7505 B work with out any modification?
Mustang Tek listed the C5 TA 7505 as a FE bell housing but not much else.
Offline rockhouse66
Re: 68 FE bell housing
« Reply #1 on: March 24, 2019, 09:21:08 AM »
I think that is a truck bell housing and is deeper by a small amount than the correct C6 one.  It can be used with a special longer pilot bearing to support the front of the trans input shaft.
'66 GT FB
« Reply #2 on: March 24, 2019, 09:56:28 AM »
I guess it's extra length is small enough it would not effect the drive shaft? I will continue to look for the correct C6 one.
Offline 67gt390fb
« Reply #3 on: March 25, 2019, 05:07:28 AM »
the C5TA-7505-B truck bell housing is about .5 inches deeper than the car bell housing.  The splines on the clutch hub will not be fully engaged on the input shaft .      The shifter would also be moved the same distance further back along with the transmission.
7R02S153xxx      12/15/66
« Reply #4 on: March 26, 2019, 12:32:42 AM »
Thanks for the information. I do not do modified Mustangs, I 'll find the correct part.
