Author Topic: Need help ID-ing misc fastners / screws  (Read 1231 times)
Offline kutzoh
  • Gold Level Subscriber
« on: November 07, 2010, 08:39:34 PM »
Cleaning up some miscellaneous odd & ends, some stuff didn't get tagged when car was torn apart. Can anyone help me ID what and where the following go. The screws have the washers fixed to them and the U-retainers have a nut fastened to them.
Greg
Re: Need help ID-ing misc fastners / screws
« Reply #1 on: November 07, 2010, 08:54:16 PM »
From left to right:
-Trunk filler board screws (should be zinc)
-J-clips, typically for installing the radiator.  Same type usually found on bumper guards, but with larger clearance in middle
-Coupe rear shelf retainer, attaches behind rear seat with spring clip
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #2 on: November 07, 2010, 08:55:54 PM »
On the top row, on the left, I'm pretty sure those two phillips screws are in the trunk, on the left side, to hold down the masonite piece that blocks off the lower quarter area.
On the top right, I think those 2 clips go at the left and right a-pillars, inside the car, and they give the windlace something to clip onto where there is nothing.
66 Metuch Conv
Nightmist, Std Blu Int
Offline kutzoh
« Reply #3 on: November 07, 2010, 09:31:26 PM »
Thanks, you guys are good!
Greg
